Question about Garden
Paslode 3250/65-F16 finish nailer is leaking air around the diffuser cap. How do I repair this problem. Will drive finish nails only partially
  • 12,061 Answers
Www.rveco.com/PaslodeSchematics/3250-65-F16.pdf
Above is schematic and parts, below is the user manual.
www.positiveplacement.com/.../3250-F16%20%20-%20403700%20-%20Manual.pdf
Your seal is faulty, and needs to be replaced, please use the parts diagram, to identify the seal and order another one, it is a simple task to replace this.
Posted on Aug 24, 2010
Paslode F16 finish nailer will not return to start position after firing. Need to pull it back.
You may have to disassemble it BUT it may be that the mechanism and sliding parts are dry and stuck with glue from nails etc so may also work to apply a rust solvent to the sliding parts and let it sit and work the nailer a bit etc.
Sep 21, 2014 | Paslode 1-1/4 In. Straight Finish 18 Gauge...
Paslode 18 gage finish nailer wont sink nails all the way
How old is it. Check the nail drive area to see if it is sticky etc. You may have to take it apart to fully check that out and/or to clean it and lube it. TRY spraying it with WD40 first.
Sep 12, 2014 | Omega Paslode 901000 Impulse Cordless...
I have a paslode 900600 . It cycles but it won't shoot nails.
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Jan 18, 2011 | BreatheAudio Paslode 900600 Impulse 16...
MY PASLODE NAILER WON'T DRIVE NAILS ALL THE WAY. THE NAIL ARE RINGED.
Check the manual for the adjustment..
heatman101
Sep 12, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
The nailers piston that drives the nails is cracked onley drives nails half way in
im afraid that if the piston is cracked, then you have to replace it ( since you know that it is cracked then ill assume that you know how to remove and replace it) you can buy one at your local nail store or you can try toolpartsdirect.com,,, please rate this ,, tks
Dec 15, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
T250S-F16 16 Gauge Straight Finish Air Nailer i have an air leak out of the front of the gun where the driver comes out and makes contact with the nail head (the hole tri-shapped hole) It only leaks after...
Air leaks from the bottom of nailers are due to leaking oring /s that seal cylinder to body of gun and/or leaking thru seal at top of cylinder where headvalve seats. Remove head and examine sealing surfaces of headvalve and top of cylinder. Must be smooth, then pull out cylinder and check oring/s that contact body of gun. Remove any fine scratches on inner body with fine paper (400 grit). Lube with silicone paste. Good Luck!
Sep 26, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
Paslode air nailer
With the Paslode cordless tools there are a couple of things that will prevent the tools from firing; a jam at the nose of the tool, a dirty combustion system and slack in the spring that pushes the finish nails forward.
First, remove the battery to prevent inadvertant firing, then check to see if you've had two finish nails driven thru the head. Remove any finish nails in the tool. Now lift the nose latch up to release the drive head mechanism. Once you have that up, you can look and see if there are any nails jammed in between the guide and the driving ram. You can push up the ram with a flat bladed screwdriver to make it easier to get the jammed nails out.
IF, the jam can't be removed easily with a pair of needle nose pliers, by pulling the nails down and out away from the tool body, you'll have to take the front nose of the tool apart (not normally needed, except in really severe jams).
If the tool isn't jammed, try putting in a new full strip of nails and pull back on the spring about a inch or two and let it go, so it'll push the nail strips all thw way forward, which will make sure the nailer isn't being locked out by the "last nail" safety switch.
Lastly, you need to clean the tool, as they don't work reliably when dirty, so follow the cleaning instructions that Paslode provides with the tool (they're tool involved and lengthy to type here)
Some other things you can check are to make sure the fuel cell cap is properly seated on the fuel cell, by pushing it all way on both sides till it clicks in place. Also, you can check for fuel flow by briefly depressing the fuel cell against a flat surface (no open flames nearby!!) to see if you're getting any fuel squirting out of the cell, as sometimes that helps to get the fuel flowing.
It also needs to be warm enough to operate. These tools don't do well when subjected to very cold temps. I always keep the batteries and fuel cells inside when the temps are below 40 degrees.
I've found that the Paslode finish nailers jam frequently due to the plastic carrier that holds the nails together, so I don't bother trying to use any small nail strips, (2-6 nails left) as they tend to cause problems. It's more productive to just use full to 1/3 strips of nails and avoid the possibility of jamming that comes with trying to load in some 2-6 nail strips.
Hope you find this Very Helpful and best regards!
Aug 24, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
I can't put mt paslode finish nailer back together again
go to Paslode.com and you can download a manual that shows the spring. It sits in a recess under the follower that pushes the nails
Jul 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode t250 f16 leaks air from the cap difuser
The most common problem with this nailer is the plastic seal that sits on top of the cylinder. This seal (ususlly white, yellow or black in color ) will cause the nailer to leak lots of air out top of gun. Examine seal for cracks and replace as necessary; the part number is 402725 and is available at www.toolpartsdirect.com This should stop the rapid air leak. After installing the new seal, if you have a very small constant leak out top of the gun then remove the screw holding the headvalve in place and check for small scratches where the orings contact headvalve. Use very fine sandpaper (300 to 400 grit) to remove scratches. Clean and re-use the same orings using silicone grease instead of oil and re-assemble. This should stop all leaks. Silicone grease is available at Lowes lumber in the plumbing department. It is used to lube orings in faucets. If you have more questions about this gun please email, Good Luck
Jan 28, 2009 | NRS Paslode T250-f16,s200-s16 Nailer &...
Garden Logo
324 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
