Question about Home
WIRE DIAGRAM FOR A FRANKLIN ELECTRIC SUBMERGIBLE PUMP CONTROL MODULE 2801074910
3 Suggested Answers
agent91
  • 2100 Answers
SOURCE: how do I change the electric wire in a franklin
You have 4 wires coming out of the fuse box , one white , one bare, one black, one red, right? The fuse is a double pole, 220 volt, ?30?amp, guessing, and you are now wiring up to a 110 volt, motor which needs 20 amps, so, remove one wire from the breaker, red or black, shut it off first, pull the wire off, tape it and mark it what it was. leave the red wire on there, or the black, it doesn't matter, Now you have one hot, one ground, one neutral, hook them up to the pump, the box on the pump has screws, one silver, one brass, the brass is always hot, the colored wires are always hot, The silver screw is neutral, the white is neutral, always, and the ground wire goes to the ground screw, maybe outside of the box. You should be all set, tape off the old colored wire you didn't use and mark it . You might need it someday. Hope this helps.
Posted on May 31, 2010
schwaa44
  • 252 Answers
SOURCE: Powertrain control module 2009 Buick Lucerne wire ground diagram location
I don't know, but you may find your wiring diagram at this website.
Wiring4Cars Free Automotive Repair Guides and Wiring Diagrams
Posted on Apr 18, 2017
I have a franklin electric 4
I have plenty of children and grandchildren, none with my name..... Cash is better but that is not what I'm doing this for.
Sounds like your system is "water-logged", shut off the pump, drain the bladder tank and check air pressure in the bladder. Set it to about two psi below the normal cut on point of the pressure switch. If that doesn't solve it, post again.
Sep 10, 2012 | Franklin Electric 1/2Hp 2-Wire 110 Vlt Sub...
I am looking for an agent for a Franklin submersible sump pump for a borehole in Centurion.
If you visit their water site along the top you will see 'service' and 'sales'. Depending on what you need select one and follow the screen prompts for a local agent. Their site can be found at:
http://www.franklin-electric.com/americas-water-systems.aspx
John
Apr 26, 2011 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Looking for model #2243019204 pond pump motor 2hp 3450 rpm 230 v ph1
This model is a well pump not a pond pump. http://franklin-electric.com/model-search.aspx Did you enter this information in a Google search? locator.aspx">http://franklin-electric.com/dealer-locator.aspx. I also see this pump is available @ Lowes if you live in the USA (please don't say).
I trust this response answers your question.
Thank you for your interest in FixYa.com
Mar 02, 2011 | Franklin Garden
I just drilled a new well and I am considering putting a Franklin variable speed Controller on the submersible pump. My question is what effect does a variable speed controller have on the life of a pump...
It all depends if the pump motor is designed to use this type of controller. If it is then ok.
I have see no advantage to these system and some disadvantages. Money, servicing and just in general more stuff to go wrong.
You make the call on this but make sure the pump motor is right for the controller.
Feb 16, 2011 | Little Giant SUBCB10 Franklin Electric...
I just purchaced a 4hp franklin spa pump. It is for a nuwave 2000 spa. The plug from the control panel has 4 wires, black, red, white and green ground. Where do the red, black and white wires attach on...
WHITE wire is your neutral so will go as blue wire.
BLACK and RED wires are your high and low speed for your pump.
I would plug red and black into either, plug in and turn spa on - if high speed comes on first then turn spa off and swap red and black wires round. the side of your pump or under top of control unit will give you a diagram of where high and low speed goes.
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 11, 2010 | Franklin Pool & Spa
We got struck by lightening a week ago. Three days ago we lost our water. We have power to the pressure tank switch. We have replaced the control box. All our fuses look good. We are not sure how to check...
You should get an electrician. We had a wire that was underground and the lightening severed it and had to replace all the underground wire to our house. Hope you have good luck. with this.
Nov 09, 2017 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
How do you wire a 2 wire Franklin 1/2 HP 10 GPM
you can just install a regular plug to the end of the wires and plug it in,, but you will need to add a ground wire,, if there is only 2 wires there should be 3 so look for a screw with a spiral clasp on it for the ground,,
Apr 21, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Home Logo
288 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
