My screen won't lite up when turned on it's a toshiba laptop
    Scholar:
  • 166 Answers
Connect an external monitor. If it does not work, remove the memory and put it back again as re-seating usually resolves this kind of issue. If you don't know how to do it, refer to your manufacturer's web site by indicating your exact model. On the other hand it can be other than the memory. (Video or more complex which can be the motherboard itself).
Please let me know if the information has been helpful to improve my support assistance. Thank you and regards.
Posted on Aug 23, 2010
Please help fix my display problem white screen what will cause this to happen
have you checked out the ribbon that runs your screen?
or it could be a lose wire some were,or earthing problem.
May 25, 2014 | Toshiba Satellite Computers & Internet
When i turn on my laptop the screen looks like a car winshield? THAT WAS HIT WITH A HAMER.
That is because the screen is probably broken. Did it get sat on or has it been dropped?
Jan 05, 2014 | Computers & Internet
My Toshiba laptop won't turn in. Yesterday I was
Unplug, remove battery, plug in reboot. OR, try a System Restore to a date before this issue. Have you cleaned the fan, vents, heatsink recently? Is it overheating? It would be helpful if we knew the Toshiba Model number and the OS you are using.
May 06, 2013 | Computers & Internet
My toshiba l675d-s7013 laptop screen won't come on?
hi
turn off your laptop take out the battery and hold the power button for 20-60 secs to discharge it and then put the battery back in and reboot or remove the battery and the ram clean the ram or try another stick of ram then press the power button and see if that restores your laptop.
if not plug another monitor into the external vga port, if the external monitor works then your laptop screen is faulty.
if the external monitor is also black or blank then the inverter inside the laptop needs to be checked or replaced.
cheers
Dec 02, 2012 | Toshiba Satellite Computers & Internet
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 21, 2012 | Toshiba Satellite E105-S1402 Notebook
Toshiba
Take apart and get a capacitor kit and replace any puffy or blown out capacitors etc. Remove and re solder new ones in. You can get kits online for you model LCD screen for external LCD monitors and you may need to replace the back lite on your laptop screen.......John
Apr 10, 2012 | Toshiba Computers & Internet
Nb 205 blank screen
Is your screen blank when you are trying to turn it on? Do the fans run and such but nothing shows up? If not then I don't know.. but if it is put you laptop in the freezer for an hour. Mine had that problem, but you won't be able to turn it off... ever again... because then it won't start up again. I would suggest to check this out as well if it is that problem. http://www.techsupportforum.com/forums/f108/toshiba-nb200-wont-boot-492391.html
Apr 02, 2011 | Toshiba NB205-N311/W Netbook
Toshiba TV will not turn on
Try to have the TV unplugged over night. If that does not solve it you may have to have the TV power supply circuit inspected for leaking capacitors, loose solders or may be a bad IC.
Aug 29, 2009 | Toshiba 32A33 32" TV
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
