Question about Nikon Monarch Rifle Scopes
I've lost the rubber ring on the eyepiece of my Monarch Ucc rifle scope. Where do I get another? danyluksteve@gmail.com
4 Suggested Answers
  • 4102 Answers
SOURCE: nikon monarch 3.3x10.44 model 6539
it sounds like the cross hairs are moving i had this problem and it was the sight not the rifle check that the mounts are secure usually one of them will slip out or the guide if it is secure then it is the scope thats the problem return it if u can if u cant it can be repaired but this can be expensive and you cant do it yourself cus it has to be recalibrated sorry i couldnt be any more help it is usually the shock that moves the cross hairs take it to a shop and they will try it for you and tell you what is wrong also check that the screws holding the rifle together are secure because it happened to me once that one of the screws had broke and was allowing the rifle to move slightly so when i lined the scope up and fired it moved and then it put the sight out try this but a rifle shop should test it for free and tell you what is wrong they will put it in a vice and fire it so then they no the gun is in the same place when fired then they will no wether it is the gun or the sight but i would say it is the sight but before you buy another check all the screws are ok and none missing hope this is some help.....................
Posted on Oct 30, 2007
  • 32 Answers
SOURCE: I have a Bushnell 3-9x32
The part is able to be replaced at a cost of about $2.00.
Contact Bushnell for agent or order online at www.bushnell.com
Posted on Oct 25, 2008
  • 6 Answers
SOURCE: Hi, I am going to purchase
I think you will very unhappy if you mount it on the carry handle. I suggest removing it and getting a Nikon M-223 mount, YOu might also want to check out the M-223 line of scopes. The 3-12x42 with Rapid Action Turret might really surprise you. I don't have one freind who hasn't tried mine out and not bought one. Hard to argue with that. Check out Nikonhunting.com Bart Nikon Pro Staff
Posted on Nov 22, 2010
I have the 6x18x65LU atn rifle scope. I had the scope mounted to my 30-06 on two 1" weaver rails. the scope keeps sliding forward though the adjustable scope rings. I've been recentering the scope and...
be cearfull you dont crush the scope tube,,but try rapping a little strip of sticky rubber or plastic tape round the scope tube then nipping the scope ring caps down onto this,,,but i think your scope rings are worn out or the wrong size,,ie 30mm not 25mm
i have air rifle scope's on my 7.62/308 and on my 303 none of them move about at all and they have stayed on zero for years now!
Aug 25, 2010 | ATN 6-18X65LU Daytime Rifle Scope
Using the scope
Well if it was a rifle, I would say far away, or you will get a black eye. But the recoil on a pellet rifle is backwards because the spring jerks the rifle forward, and it messes with rifle scopes, they are made to recoil back, But,,, you have a movable eyepiece in the end where you look through and it will make the cross hairs come into focus for your eyes. some one else might find them blurry. The objective lens, should be in focus no matter what. It doesn't move. and no matter what your vision is, you should be able to see clearly. If not, I'm wondering if it is fogged up. Your eye should be about 3inches, + -, Check it out. Hope this helps.
May 04, 2010 | Crosman 4 x 32 Air Rifle Scope, Black
Simmons 8x32-44ao rifle scope
Is that the "Prairie Master"? I think Simmons is pretty uniform in that range of scopes--elevation adjustment should be the top dial and windage is on the side. The zoom locking ring should be in front of the eyepiece, with the zoom ring just forward of that.
You can download a generic Simmons scope manual from the Simmons site at this link: http://www.simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Mar 31, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
The magnification adjustment ring on my Gamo Whisper worked fine at first, then was stuck between 3X and 5X. Now it is free again but the scope is not focused on the 3X and 9X settings, but is clear on 5X...
I'm not familiar with the scope, is it an air rifle scope? One stroke type? If not, the backwards recoil of the air rifle is tough on a normal scope, they aren't made for that type of abuse. They work fine with a normal recoil. That is why they started making air rifle scopes. I'm sure that the internals of your scope are damaged somewhat, you can take off the eyepiece no problem, you might find something in there, loose screw, missing screw, you never know, don't get too carried away with the dis-assembly, you'll never get it back together. It sounds like the magnification ring is messing with the focus of the eyepiece. Might just need some oil. Hope this helps.
Feb 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
I have to use reading glasses to use a simmons blazer rifle scope.....othewise the image is blurry.
You can't see the cross hairs or the whole picture is blurry? I know that the rear ring on the scope will bring the cross hairs into focus, glasses or not, and the scope itself should be clear all the way down, I can't see a thing either without glasses and it has really hampered my shooting. It ain't no fun , it's frustrating. Try turning the rear eyepiece, see what happens, hope this helps.
Feb 27, 2010 | Cabela's Cabelas Pine Ridge 3 X 9 X 40...
I´ve lost the ruber O ring of the ocular - the one that prevents injury to the face of a Bushnell Armorsight Were com I find a replacemant, since Bushnell doest produce them any more? Thanks...
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Jan 05, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
Nov 15, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
Buy riflescope!!!! Which one????
Robert, I have the Simmons 6-21x44 MilDot # 511056 scope on my Savage model 10FCP Law Enforcement issue rifle. I think you should check it out. It has 90 MOA internal adjustment and you could get you something like a 15 MOA or 20 MOA tactical rail and push your adjustments out to 1000 meters!!!
Oct 03, 2008 | Nikon Monarch UCC 6.5-20x44 AO Matte
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
Optics Logo
82 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
