Question about Epson AcuLaser C8500 Printer
Problem for Epson AcuLaser C8500 Printer error code: c0084 The machine has done less than 25K prints - but has been stored for 3 years.
  • subiacoskype Aug 23, 2010
    Super nonontech - it turned out to be a faulty RAM chip. Status sheet printed out fine - only 9680 prints from this machine, so I'm really happy it has been saved. Many thanks, R.
    Very helpful advice - indicating a data issue helped me track down faulty RAM. Wonderful service, many thanks! R
  • Epson Master
  • 4,737 Answers
This error code is displayed when there's a temporary "data error", means transferring data from computer to Printer to make the print outs.
It could be a corrupted or interrupted print job. It's also possible that the Data cable (usb cable) is loose or not properly connected on the computer or on the printer.
Try the following Steps:
First of all, disconnect usb cable from the printer and from the computer (unplug both the ends of the cable) Leave it Off for few minutes and then print a test page or status sheet. (do this before you connect it to the printer) Verify that there's no pending print Queues in the Print Status, if so Cancel them. Now reconnect the usb cable to the computer and on the printer. You are ready to test the printer.
If there's memory installed, please reseat it. Sometimes it's important to restart your computer. So I would suggest you to restart your computer while you keep the printer off.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Aug 23, 2010
  • Lebanon Raingam
    Lebanon Raingam Aug 23, 2010
    I am glad that your problem is fixed. Hope to help you next time also. Your Rating and Testimony is appreciated. Once again Good luck.
Espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
May 14, 2010 | Epson Aculaser C1100 Printer
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
Epson Aculaser C1100 error code C0084. How is this code cleared.
Hi
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1374
Feb 15, 2010 | Epson Aculaser C1100 Printer
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C8500 Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
