Question about Juki DDL-8700
Hi, I have a DDL-5550-6 Juki industrial model. I had problem inserting a new needle; I read the advice about inserting the scaff on the right, because my bobbin is inserted on the left. Now the thread continues to come out, I tried adjusting the tension, please help:(
    Scholar:
  • Juki Expert
  • 176 Answers
Hi there
1 - are you sure you are use DBx1 needle ?
2- check tension spring for bobin case it's not open too much gust pull the threrad you will feel light tension not too much not too losse.
3 - check timing between needle and hook is ok orno?
best regards
ashraf abozid
aabozid@hotmail.com
Posted on Oct 30, 2010
Error code E3 45786 on Juki sewing machine motor
I could not find that error using the Manual that is on the Internet.
I suggest you call or email their Sales and Service in the U.K.
Their email is sew-europe@btconnect.com
JUKI DDL 5530 DDL 5550 Parts Needles Service
Feb 16, 2015 | Juki DDL-5550 Industrial Straight Stitch...
My Juki DDL 5550-6 machine is not turning on. How do I fix this?
HI Gina
did you please check power source coming to power switch or No ? one more thing , please let me know which control box model you are using then i can send to you photo for fuses place to check maybe one fuse burned and need to replace.
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Feb 09, 2015 | Juki DDL-5550 Industrial Straight Stitch...
How do I know that machine is in working condition ddl-5550
A little more information please. I have this model, and it only does a straight stitch and reverse.
Have you turned it on and tried sewing on it? Is the oil pan dry? Has it been serviced at all, or maintained?
We can't help you without more info.
Oct 15, 2014 | Great Plains Ind. Juki DDL-5550 Industrial...
Black oil marks on fabric when sewing
theres a screw that controls the amount of oil that reaches the upper head. tilt machine back and look for screw with head that has an arrow indicating + or - tighten in minus direction. maybe u need a new needle bar guide too.
Mar 20, 2014 | Juki DDL-5550 Industrial Straight Stitch...
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Juki ddl 5550-6
can you tell me your control box model? some model of control include variable resistor to adjustment the speed for thread trimmer.
a waiting your answer about control model and i will help you.
thanks
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Dec 07, 2013 | Juki DDL-8300
There is a wrong way and right way to insert a new needle in an industrial juki sewing machine. I happen to have a computerized model which way does the needle go into the machine?
-If your bobbin case is inserted from the left side of the machine, then the scarff( indentation on the back side of the needle ) should be on the right side as you insert the needle.
drtension
Apr 23, 2010 | Juki DDL-8700
I just got a used juki ddl-5550-6 sewing machine. There is no owner's manual. I think I have the machine threaded right. When I put the pressure foot down to start sewing, it pulls the thread down into the...
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
Jul 08, 2009 | Juki DDL-8300
Juki DDL-8700 Logo
342 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
