Question about Toro Garden
I need to know the correct sequence for dismantleing a Toro Consumer 71282, 17-44hxl riding lawn tractor. The part that I broke while trying to disassemble the tower assembly is the brass rod-tower pivot part # 100-7401. The rod has two 5/8" cap nuts protruding on the outside of the tower. When I attempted to put 2 wrenches on either end, the rod-tower pivot part just snapped. Is that the correct sequence to remove the bar and I just have too much corrosion freezing the nuts? How much of the steering wheel etc do I need to remove in order to remove the tower? Thanks
  • 142 Answers
SOURCE: front wheels of our riding lawn mower
Most front ends for riding lawn mowers, need to be greased. In addition to this, most of the rims for the front tires, have a nipple for a grease gun, which also need to be lubricated.
Posted on Sep 20, 2008
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
lester482529
  • 226 Answers
SOURCE: the steering wheel on my toro lawn tractor is
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: How do I remove the steering wheel from a TORO
It will either have a roll pin on the underside of the wheel, or under the decal in the center of the wheel (which should pry off with a small flat screwdriver) it will be held on by a nut.
Posted on Nov 28, 2009
  • 150 Answers
SOURCE: John deere 68 riding mower steering column won't
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Posted on Sep 27, 2010
Testimonial: "sounds good will try to fix it thx"
Blades won't engage on my toro ss 5000 zero turn mower
for any ride on machine that the blades don't engage id start at looking at occupancy seat switch , these are most times the culprits then if that's ok I move on to the actual engage switch and then on to clutch as last element
don't forget that past 2013 mfg machines operator must be in seat and weight over 80 lbs , the clutch pedal must be depressed and transmission not in reverse to engage the blades on a consumer grade lawn tractor (thank the CSB for that )
Aug 27, 2015 | Toro Garden
Toro 57360 lawn tractor transmission problems
It might have run out lube and seized pull out and check.
Sep 12, 2014 | Toro Garden
Remove a clutch assembly from a toro 264-6 mod. 72042 lawn tractor
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual
May 31, 2011 | Toro Garden
How do i replace a drive belt for the toro lx425 lawn tractor?
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
Oct 10, 2010 | Toro Garden
Pull cord wont retract on my toro self propelled lawn mower
Sounds like a spring problem. Remove starter shroud, try pulling it and see if it works. If the spring isn't broke you may have to take another rap on the rope to gain more tension, or spray mechanism with some wd to free it up.
Sep 28, 2010 | Toro Garden
Toro lawn mower
You may have overserviced the oil.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
43 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
