Question about Belkin (F5D7011) 802.11g/b Wireless Adapter
Can't connect to the internet
The list of things I have attempted to get this computer to connect to the internet is extensive. It was given to me by a friend and it had AOL on it, which I promptly removed. It won't connect neither through wireless on the card or through the on board network adapter. I've tried connecting both through my router and then by directly connecting the computer to the DSL modem using the appropriate network cables. I've uninstalled and reinstalled TCP/IP, reset the TCP/IP stack, checked for possible proxy settings, made sure the AOL service was disabled and that wireless zero was enabled, I've let the Belkin software try to connect it and I've also let windows try to connect it, I've tried both with the Windows firewall enabled and disabled. I'm out of ideas. Help.
  • 3 more comments
  • Amy H.
    Amy H. May 07, 2008
    Wow. So I think I have a bigger problem than I may have imagined...
    When I ran ipconfig /all I got the following IP address for the ethernet adapter: fe80::202:3fff:fe74:3025%4.
    I've never even seen anything like that before...
    I tried this as you asked me to, with the laptop connected (wired) directly to the router. I then took the router out of the picture entirely and just connected the laptop to the DSL modem as I normally would if we only had one computer in the house. I got the same result both times.
    I know that the router is good. I have a desktop and an additional laptop that connect to the internet just fine through it.
    The plot thickens...
    Thank you for your responses. I hope someone can help. :)
  • Amy H.
    Amy H. May 07, 2008
    I have also tried connecting it through the PCMCIA slot with a Belkin wireless card. No dice. This makes me think it's not a hardware issue.
    I did try repairing the connection for the ethernet adapter previously. Then I tried deleting it entirely and creating a new one. It is set to obtain an IP automatically.
    I don't have a firewire port showing in my Network Connections.
    I will go ahead and try disabling the ethernet adapter and then report back. :0)
  • Amy H.
    Amy H. May 08, 2008
    Partial success! I disabled/reenabled the network adapter and we are now able to connect while wired up to the router! Thank you!
    Still no success connecting through the Belkin Wireless Card that goes into the PCMCIA slot, but I'm pretty sure my family will just be happy that the computer can now access the internet.
    Many, many thanks to all.
  • Jason May 11, 2010
    Connect the laptop to the router via wire (not wireless). Open a command prompt (Start->Run, cmd ). In the dos box enter:
    ipconfig /all
    If the address is 169.x.y.z, you have a problem.
    Post the information and we'll help you out.
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    did you chekc if you can ping the wireless router locally, or if you can ping any websites like yahoo or google?
    Novelist:
    Scholar:
  • 134 Answers
Good advice, but maybe go to control panel, network connections, highlight local area connection (left mouse click) then right mouse & select 'repair'. That does a whole heap of things as well as a reset. P.S. do you have the connection setup as DHCP.. Or obtain IP address automatically? I assume the other pc's in the house are.. That way, the router is meant to provide an IP address..
Posted on May 07, 2008
  • Dave117
    Dave117 May 08, 2008
    Just a thought from another user on Fixya..
    you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
    Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
    Try that, to get the wireless side working.. Might help. Obviously disconnect the wired side first, just for the test. Rgds,
  • 77 Answers
I've never seen that, so I'd go so far as to say it's a hardware issue, ie, you have a bad nic card.
Try this, though: From device manager, with the laptop wired, disable the ethernet adapter. Then reenable it. See if that corrects it. Sometimes, all it needs is a reset (the port). I've seen that fix many a problem. Also, if you have a firewire port showing up in Network Connections (IEEE 1394), disable that (again, in Network Connections). If none of that works, I'd try buying a PCMCIA NIC or maybe a usb one.
Need to disable Adblock from pch games
Chrome has Extensions. Each extension does a different service. Try this. On top of chrome screen go to the right. Find a series of 3 dots (...) use you mouse to click on the dots. Try left button click. IF nothing happens try a right click. A list of items should appear. IF there is one for, EXTENTION, CLIK IT AND THERE WILL BE CHOICES AVAIABLE TO YOU. WHEN YOU REACH ADBLOCK SET IT OR TURN IT OFF.
IF the word extension is not there, look for the word SETTINGS and if you are given a list of choices , look for extensions and turn adblock off.
IF all fails go to technical support and request help.
Sep 26, 2017 | The Computers & Internet
No network coverage
Set IP Address Configuration
Click the "Start" button and select the "Control Panel" from the right column to open it.
Select the "Network and Internet" section of the Control Panel.
Click "Network Connections" if using Windows XP to view the available network icons.
Or, click "Network and Sharing Center" if using Windows 7 or Vista and select "Change adapter settings."
Right-click your network connection icon which displays either the yellow triangle or red "x" indicating limited or no connectivity.
Select "Properties."
Click on "TCP/IP" to select and highlight it. Click "Properties."
Select both the "Obtain IP address automatically" and "Obtain DNS server address automatically" radio buttons.
Click "OK" and then "Close" in the Network Connection Properties box. Close the Control Panel.
Manually Renew IP Address
Click the "Start" button and choose "Run" from the list.
Type "cmd" in the "Run" box and press "Enter" to open the Windows Command Prompt.
Type "ipconfig /release" in the Windows Command Prompt and press "Enter."
This releases the current IP address of your computer.
Type "ipconfig /renew" and press "Enter" to obtain a fresh IP address.
When renewing your IP address, Windows automatically attempts to connect to the network.
Powercycle Router and Modem
Turn off your computer.
Unplug both the Internet modem and wireless router's power adapter from the electrical outlet. Wait for two minutes.
Plug the Internet modem into the electrical outlet first. Wait for connectivity lights to appear.
Plug the wireless router's power adapter back into the electrical outlet.
Confirm that lights appear on the router indicating that it has established a connection to the modem.
Turn on your computer.
Open "Network Connections" if your computer does not connect automatically to the network.
Select a network from the list, input the network password if one exists and click "Connect."
Open your Internet browser to test the connection.
Update Network Interface Card (NIC) Drivers
Click the "Start" button. Right-click "My Computer" or "Computer" from the Start Menu. Select "Manage." Click "Yes" if a user account control message appears.
Click on "Device Manager" from the list of System Tools.
Find the "Network adapters" listing and click the "arrow" or "plus" symbol to expand it.
Right-click your computer's network adapter from the list and select "Properties."
Click the "Driver" tab and select "Update Driver."
Follow the on-screen prompts to allow Windows to find and install the drivers automatically. Restart the computer when the process is finished and attempt to re-connect to the network.
Reset Internet Protocol (TCP/IP)
Click the "Start" button and select "Run."
Type "cmd" and press "Enter" to open the Command Prompt.
Type the following line into the Command Prompt and press "Enter":
netsh int ip reset resetlog.txt
Close the Command Prompt. Issuing this command tells Windows to remove and then re-install the two registry keys used by the Internet Protocol (TCP/IP) component of Windows.
Restart the computer.
Attempt to connect to the network if a connection is not established automatically.
Sep 06, 2013 | Computers & Internet
I cannot open my internet it says i need to reinstall WRusr.dll before i can open it how do i get it back without the internet?
Check you antivirus and firewall settings make sure internet is allowed.
Internet connection and network errors can be frustrating and confusing to a casual computer user.
However, Internet Explorer provides a diagnostics tool to help identify and even repair the most common network issues.
This tool is simple to use, organized in steps, and can help get a computer back up and running quickly.
Open Internet Explorer and click on the "Tools" button in the control bar at the top of the window. From the "Tools" menu, select "Diagnose Connection Problems."
A window will appear, displaying the start page of the diagnostics tool.
Follow the instructions to determine the cause of the connection error.
The diagnostics tool will ask a series of multiple-choice questions about the connection problem you are experiencing.
Close all programs and restart the computer.
If you continue to receive an error when attempting to connect to the Internet, check that all cables and power-supply cords for the computer, modem and/or router are properly connected. Then, run the diagnostic tool again.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options or
Click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search Providers
Toolbar extensions and Accelerators you have if don't need any of them you can disable or remove them
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an internet connection
May 09, 2013 | Computers & Internet
Flashing lights with no fans, held power button down & now only red lights (internet adapter, volume button) & fans are working why? help?
this sounds like a hardware or driver issue
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) Sata make sure they have dust free secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
or you might try
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
May 10, 2012 | HP Pavilion dv7-1130us laptop
I have fujitsu amilo pi 3540 and since i bought a cheap second gen ipod sync lead it just wont start up any more!
it sounds like it might have given it a jolt to something electrical or a device
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Apr 16, 2012 | Computers & Internet
Following rebuild of laptop i have downloaded internet explorer 8. The icon states "internet explorer 8 - without add ons" When opened the information bar states internet explorer operating...
Internet 8 has a compartibility requirement considering the operating systems of the computer, though to an extent the system settings that makes possible adjustments after installation. Once the software has been installed on the computer, any further add on softwares becomes impossible. Newer computers would allow every download especially from the internet onto computer storage with a message of malfunction thereafter. Internet 8 requires operating systems compartibilities to intergrate into the computer achieving additional software intergration. Consider using another internet browser as immediate alternative to resolving internet connectivity issues.
Dec 07, 2010 | Microsoft Internet Explorer 8
Hi, im using a brand new acer asprire x1800 desktop..and i can HARDLY connect to the internet using SUN BROADBAND (lan connection already disabled). i have been using the broadband for a few months now....
There could be several possibilities for your internet connection to slow, or stop functioning. Here is a small list of things to check:
1) Run Spybot Search & destroy:
This is a program that will help you find, and eliminate malware, it's free from Here. It also helps speed your PC up by removing unwanted malware that can drain your system's resources.
2) Check your scheduled tasks to determine nothing is set to run during these " down " times.
3) Check to make sure any wireless connections are secured using WEP or other such wifi security. It's a little known fact that people will " pigy-back " on someone's wifi connection to use the internet and download. this can cause internet instability.
4) Call your Internet Service Provider. Your ISP can usually help you determine if the problem is with your computer or their connection.
5) Check your network settings. Your ISP can help you determine the best settings for your connection, as well you may check to see if the network device has an updated driver from the manufacturer.
6) If all else fails, you may wish to take your PC to a licensed technician, or replace the network device if you feel it is faulty.
In my experience most internet instability that happens on a regular basis during a set amount of time is due to malware, or scheduled downloads.
Nov 03, 2009 | Acer Aspire™ T180 PC Desktop
Share internet connection
Connect the HTC to your desktop through USB. On the HTC: Programs >Internet Sharing. Choose USB under PC Connection.  Choose My Connection (or whatever name you have given for your internet connection) under Network Connection. Click: Connect.
Of course, for this to work you must have an internet connection (GPRS or Edge) on your mobile.
Feb 24, 2009 | HTC P4300
Takes 2 to 3 attempts to open Explorer
Define your router IP address as DNS server in your TCP-IP protocol (Control Panel, Network adapter)
Jan 19, 2009 | Microsoft Internet Explorer 7
I have an acer aspire laptop i cant connect my wi-fi is on computer shows one hundred percent signal but wont connec--joe
If the Wireless connection you're attempting to access is your own, you will need to take some steps to discover your wireless connection's authentication password. If however the wireless connection you're attempting to connect to is not your own, don't continue reading unless the person who owns the wireless connection has given you permission to connect to their network.
Anyways, the easy way to discovering your router's wireless connection password would be to check the router's manuals for the default wireless encryption password. If the password listed doesn't work when you attempt to connect to the wireless connection, or if you don't have a manual, try the hard way...
The hard way requires you to directly connect to your router via a CAT5 (Ethernet) cable. Afterward follow these instructions for gaining access to your router's control panel:
Go to Start>Programs>Accessories>Command Prompt. From here type in: ipconfig
PressENTER to execute the command. A list should be returned listing some IPAddresses. Look for the one associated with, "Default Gatewaty."
Here is a picture.
Afterward open your Internet Browser (Internet Explorer, Firefox, etc...) and type the IP Address associated with the default gatewayinto the address field of the browser. DO NOT add www. or .com.Afterward press ENTER or click GO as if you wanted to visit a website.
Here is a picture.
Onceyou're at the control panel you will probably be asked to log in. Ifyou do not know your login details you can always try the default. Tofind these you can either search your router's user manual or head tothe online search engines entering your router's manufacturer's name,the router's model #, and the words, "default password" into the samesearch request to bring up the default login credentials. For example:
Linksys WRT54G default password
Here is a picture.
If you still can't manage to log in to your router's control panel you will have to contact the technical support department of your router's manufacturer asking them for assistance in resetting the login user ID and password of the router.
Once you manage to log in to your router's control panel, locate the area of your router dealing with the wireless settings of your router. Once you locate that region make sure the authentication type is WPA-PSK and that the encryption type is TKIP. If those options are not available, just use the WPA authentication/encryption type. Afterward locate the region that lists your router's authentication password. Once you locate it write it down or follow instruction to locate it.
Once you have your wireless password written down attempt to connect to the wireless connection using the password you just wrote down. If it works, hooray! If not, try altering the, "Wireless Mode." While, "Auto" is convenient, not all wireless adapters can work with it. Change between the modes attempting to connect to the wireless connection every time you switch it to a new mode.
If for some reason it will still not connect, consider contacting the person who made your router for assistance in connecting to the wireless connection.
Jan 17, 2009 | Acer CASE Mid-Tower ATX P4 350W FAN DUCT...
Belkin (F5D7011) 802.11g/b Wireless Adapter Logo
171 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
