Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
Where can I find parts for the steamer (brush heads)
  • 694 Answers
Bissell power steamer brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
RONSHESTACK@AOL.COM
Scunci International
2200 Byberry Road
Hatboro,PA 19040
Google search should provide a lot of options for obtaining the brush's but don't forget EBAY as it has been sometime ago but I had bought brush's for my steamer threw then. Good Luck!
May 25, 2014 | Scunci SS1000 Handheld Steam Cleaner
I am trying to find somewhere to get spare parts (in particular the small detail brush) for this two-year-old steam cleaner. It appears that Domotec no longer have a UK distributor but I think they do...
Domotec does not exists anymore , however you can buy from www.espares.co.uk : Vax Steamer Nylon Brush (ES956244) which is similar to the one supplied with Domotec steam cleaner.
Jan 03, 2011 | Vacuums
I need replacement parts for my Scunci SS-1000 Steamer
hi i need this part for my scunci steamer model ss-1000 this is internal parts inf to dannacielcr@hotmail.com thanks
Jun 04, 2010 | Scunci SS1000 Handheld Steam Cleaner
Need manual for bissel powe steamer brush select
User Manuals can be downloaded from the Bissell website
Feb 07, 2010 | Vacuums
How do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
May 07, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I bought a Bissell 1695 power steamer from a friend without a manual with instructions nor the attachments. Can you help please??
Hello, I went to a local repair shop & was told that I may as well trash this Bissell 1695 model because very few parts were available & none were what I needed. Of course, I have to research things for myself & to try to keep from buying a new power steamer. Called Bissell Customer Service. CSR told me that the model was discontinued, none of the parts that I need are available & referred me to five authorized KY dealers (all of which are an hour or more driving time away). I am going to call all of them tomorrow & hope I can find a solution to one broken pivot arm that holds rotating brush roll. I found a helpful website that has a schematic and lists all parts that are available to order (& unavailable). There is also one service note regarding the parts that I need that says the entire base assembly with brush motor must be replaced because of a design change. Of course, it's not available either. Hope this helps some. The website is: hescoinc.com
Dec 19, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Brushes not turning on 8920 2x Bissell
Brushes are switched on by lowering the handle which activates a micro-switch located inside the lower part of the machine. Vacuum must be running as well. The DC power for the brush motor comes from a Bridge rectifier located on the PC board located in the handle. I have drawings that might help you.
petedcurtis@gmail.com
Nov 26, 2008 | Bissell 8910 ProHeat Clear View Upright...
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
114 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
