Question about Airlink AR430W Wireless Router
It wont restore to factory defaults by pushing the reset button for 30 seconds. As far as i know i never put a password on it in the first place. And the Admin Admin stuff didn't work,
  • Airlink Master
  • 7,733 Answers
Read http://airlink101.com/download/download_links/q-ar430w.pdf
Posted on Oct 10, 2013
I tried to change my password and i closed the page before it finished and when i tried to connect to the internet it wont work help
Perform a reset. Find the hidden reset button, usually close to power line, find a small hole with a little button behind it. Use a toopick or similar to hold down power button for at least 10 seconds. This should restore it to factory setting and default password. Google the model # and brand and "default password" if you don't already know it. If this does not work to reset it, then try this...
Hold down reset button for 30 seconds, still holding button pull the power out, keep holding button for 30 secs, STILL holding button - plug in power then release button after 10 secs.
Yes 30 secs each cycle is overkill, but allows to be sure.
Aug 11, 2013 | Computers & Internet
Who to reset password
In order to reset the password to the default one you must reset the router.
To do this there will be a tiny button like in this picture: logicaldemen_0.jpg
Hold the button for about 30 seconds and it will be reset to the default password. Which depending on the model it could be (User: "blank" Password: admin)
You will have to reconfigure your router after this, but that should get you up and running.
Hope that helps.
Thanks Bruce
Jun 13, 2011 | Linksys Wireless-G Broadband Router
How can i reset Encore enRTR-104 router to default factory settings? When i push the reset button after few seconds begin the light nr. 4 faster to blink. When i release the button - the reset is done in...
I found these instructions for resetting the router to the defualt settings:
Use the "Backup Settings" tool to save the Broadband Router's current configuration to a file named "config.bin" on your PC. You can then use the "Restore Settings" tool to restore the saved configuration of the Broadband Router that you set before. Alternately, you can use the "Restore to Factory Defaults" tool to force the Broadband Router to perform reset and restore the original factory settings.
􀁺 Restore Factory Default
To restore the factory default settings of the Broadband Router, click on the "Restore" button.
􀁺 Backup Settings
Press the "Backup Settings" button to save the current setting in a filed "config.bin" or given filename.
􀁺 Restore Settings
To restore the backup file to the Broadband Router, enter the path and filename on the restore settings.
You can find the manual here:
http://www.encore-usa.com/us/support/ENRTR-104
May 05, 2011 | Encore ENRTR-104 Router
I have an WNR1000 and I have lost the password but have the disk. How do I reinstall?
On the back of the router there is a very small button something you would need to use a paperclip or other small object to push push and hold that button for a few seconds that will restore the factory default settings to the router. then admin should be the user id and leave the password blank to get into the router settings
Mar 23, 2011 | NetGear WGT624 Wireless Router
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
Forgot my password and user name
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 21, 2011 | NetGear WGT624 Wireless Router
How do I reset my Linksys WRT400N Router to factory defaults
Reset There are two ways to reset the Router's
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router's web-based utility.
There should be a small hole with a red circle around it on the back of the router next to the power plug hole. Use a pin or straighten paper clip to push the tiny button.
Jan 11, 2011 | Linksys WRT400N Router
I have a ASUS wireless router. It worked fine when I first installed it. now it is asking for a security key and I don't know what it is.
Do a HARD reset on the router by pushing the RECESSED reset button for 30 seconds. Do not confuse the Red 'EZ Setup' button with the RECESSED reset button.
This restores the router to factory defaults which includes the default SSID and password. The WiFi password is reset to none.
Now setup the router according to your manual and write the SSID and password down and paste it to the bottom of the router.
If this fixes your problem, 4 thumbs would be appreciated.
Sep 16, 2010 | ASUS Computers & Internet
How do I reset my router's ssid and wep settings. Also, I don't remember my router user name or password
There are two ways to reset the Router's factory defaults. Either press and hold the Reset button for approximately five seconds, or restore defaults > Factory Defaults in the Router's web-based utility. I suggest just press the reset button will be the best option since the router username and password cannot be retrieve. 81ddc0b.jpg
Router default IP address is 192.168.1.1 Password screen pop up by default username <blank> password admin.
Nov 21, 2009 | Linksys Wireless-G Broadband Router
Need to reset router
If you reset the router you will lose all the settings of the router.
On the router you will find a small reset button .
Hold it down for 30 seconds.
Unplug the power cable and plug it back in.
wait for 30 seconds and then reconfigure the router.
Click Here for more info about router set up.
Oct 20, 2009 | Siemens SpeedStream 2614 Router (ss2614)
Open Questions:
Airlink AR430W Wireless Router Logo
178 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
