Question about JVC AM FM CD DET FACE CAR STEREO
My jvc car stereo says protect when i turn it on. i press the reset butten and take the terminal from the battery. it goes on for 5 min and says protech again. can jou help me pleas.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 2,226 Answers
Try checking your speaker wires and speakers for shorts. if they check out fine, you may have a bad output ic inside the deck.
Posted on Aug 23, 2010
Jvc car stereo warning wiring chk then reset unit
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Apr 18, 2014 | JVC AM FM CD DET FACE CAR STEREO
My JVC car stereo display " Protect " on display
FIRST PRESS THE RESET BUTTON BEHIND THE FACE IF DONT WORK CHECK ALL SPEAKER WIRES SOMETHING MIGHT BE TOUCHING
Jul 24, 2011 | JVC AM FM CD DET FACE CAR STEREO
My jvc deck says PROTECT on it and won't let me listen to music or anything! What should I do?
my jvc kd-s37 keep going into protect mode now how can i get it where it stays out i reset it several time but it still goes back into it
Nov 25, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC drains battery when OFF, puzzling
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
Jan 12, 2009 | JVC KD-HDR1 CD Player
Hxd7 protect
Don't buy a stereo that prints up 'PROTECT MODE' and then does not tell you how to cure it. This is a good way of getting people to buy a new one only live and learn do not buy the same manufacturer again. I have a nice just out of warrenty JVC that when I switch it on sits there grinning at me with 'PROTECT MODE' showing. Yes I have entered cash protect mode and decided I am not going to buy another JVC.
Jul 26, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Protect
The protect message indicates that a problem has been detected in the final output stage of the amplifier. The most common failure parts are the output transistors. Plan on a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
May 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Tv want go on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source)
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
PROTECT and shuts off
I had the same problem with a jvc stereo set, it turned out the two cables of a speaker were touching each other.
Sep 20, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC AM FM CD DET FACE CAR STEREO Logo
541 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
