Question about Dometic RM2652 Refrigerator
I have a Dometic Americana refrigerator that is not working. When I first turned it on, everything was fine. I left for about an hour and when I came back, there were no lights on the control panel or the interior. I checked the power going to the back of the refrigerator and it has power going into the circuit board. I do smell a very faint smell of ammonia, but it is not very strong. If the cooling unit is out, would that also cause the lights not to work inside the unit and on the control panel?
    Habit-Forming:
  • 20 Answers
These often have a recall kit installed that has a thermal fuse in the burner area....when the burner overheats the thermal fuse shuts the hole thing down to prevent fire, the ammonia smell is probably from the cooling unit. check under your burner, to see if you see a bright yellow powder or liquid if you do, your cooling unit is for sure bad and is dangerous to run. The thermal fuse shuts the fridge down completely and can be reset by pushing in the button in the middle.
I have a Dometic Americana refrigerator that is - burnerleak-jmduatzj5u453czeggo3naf5-2-0.png
Posted on May 21, 2017
  • 68 Answers
SOURCE: Dometic Americana Freezer/Fridge not cooling
The recall has nothing to do with your fridge not working. Your cooling unit has gone bad. And yes you can get a new fridge for a few hundred more than a new cooling unit. And sooner or later PPL motorhomes will run out of their cheap stock. The fridges they have are out of production. I know I am a Dometic dealer.
Posted on Mar 19, 2009
  • 96 Answers
SOURCE: Ammonia smell when Dometic Air Comditioner is on
sounds like you have an old unit and it has a leak , the real old units where filled with ammonia as the gas
Posted on Feb 16, 2009
  • 127 Answers
SOURCE: My Dometic has a very styrong smell of ammonia.
TURN THE REFRIGERATOR OFF AND DO NOT USE!!!!
You have a bad cooling unit. This is the entire assembly on the back of the refrigerator that draws the heat out of the box. You will have to either have the cooling unit replaced or buy a new refrigerator. The cost difference is usually around 200 to 500 depending.
Hope this helps,
Jeff
Posted on Jul 06, 2009
  • 9 Answers
SOURCE: dometic rm4223 has leaked coolant. The
You need a new cooling unit. That ammonia smell means that your heating unit is shot, needs to be replaced, and there are a coupla ways to go here.
1) Order up a rebuilt (or new) online, and replace it yourself. (Handyman skill level:fair.) $500.
2) Go to an RV repair shop and have that done $700.00 - $100.00
3) Buy a new fridge. $1000.00 ++
Posted on Jul 26, 2009
milten1
  • 1304 Answers
SOURCE: AMMONIA SMELL
you have a sealed sytem leak
a very expensive repair
Posted on Oct 08, 2009
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Our fridge stopped working? wont work on gas or electric.
disconnect thermistor let run if ok replace if not bad board
May 31, 2013 | Dometic DM2652 Americana Fridge...
For some time now our Dometic Americana Refrig. would not get below 40 degrees and now we have a different problem. It will not get above 20-25 degrees and we have tried everything we can possibly think...
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
The Dometic is a good unit, however, sometimes things work loose and connections get corroded. On many occasions, I have fired my unit up in all modes and checked it out, drive 100 miles down the road and then have to clean connections reseat everything, etc.. One of the biggest problems is the DC connections. It seems like I am constantly cleaning the connections.
Jul 15, 2011 | Dometic RM2852 Refrigerator
Our Dometic Americana in our RV is too cold and is freezing everything. We have had the thermal coupler replaced to no avail. Can you help?
just tried moving the temp sensor closer to the "fins" in the fridge part...we'll let you know if it works. The sensor is placed in a plastic sleeve that holds it to the fins. I have moved it so the tip of the sensor wire touches the end fin.....
Jan 17, 2010 | Dometic Refrigerators
Jan 11, 2009 | Dometic RM2852 Refrigerator
Change right hand door ,to left hand
Not sure with this model but most time you can and I'm sure this is no different, look at the screws holding the hinge bracket, there should be identical screw holes to match on the opposite side.
Aug 06, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
245 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
