Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
CH670-0011 22hp in cub cadet 115 Hours smoking replaced head gasket but observed that ring job was needed Is this a normal problem with the Kohler V twins?
    Scholar:
  • 97 Answers
No it is not common long period's of sitting the lube will wash off the rings and a squirt of oil will help prolong life of the rings that's if the engine was sitting for a wile hope this helps
Posted on Sep 01, 2010
Did you mean: i have a cub cadet 1040 ltx that is running rough and loud?
Head Gasket possibly
You should be able to find out where
the noise is coming from
Oct 11, 2014 | Cub Cadet Garden
What does white smoke coming from a cub cadet lawn mower mean
Most likely the valve seals or the rings are bad and the engine is burning oil.
Oct 06, 2014 | Cub Cadet Garden
Have a 22 hp kohler engine on a cub cadet comerical mower it smokes black smoke and pops through carb with no power
burnt a valve out need valve job with new valves might have also lost rings in one cylinder wont no till you open it up
Sep 11, 2014 | Garden
What caused 19 horse Kohler to belch white smoke
white smoke fuel blue black white smoke oil over fill oil will cause it getting to much fuel will cause it check carberator check oil
Sep 02, 2014 | Cub Cadet Garden
Cub cadet trouble shooting
bad rings need to rebiuld motor
Jul 04, 2014 | Garden
Blowing white smoke
Either the valve in the breather is not working properley and causing a pressure rather than a vacume in the crankcase, or the piron rings or cylinder bore are worn.
May 28, 2013 | Cub Cadet Garden
Zx2 98escort idles fine no smoke when u start down road pours white smoke
Hi Sherry, If the smoke is a whitish blue grey, Best observed while standing behind the car and while parked with the parking brake on and asking a friend to run the engine at about 2500 RPM. If the smoke is evident then it probably means that the piston rings are worn or damaged and the engine needs to be rebuilt or replaced. If you have had any overheating problems, it could also be a blown cylinder head gasket, which to repair is also a major job. Regards John
Sep 21, 2012 | 1999 Ford Escort
Excess smoke
The general rule: white-ish smoke indicates coolant in the exhaust, meaning a blown head gasket, whereas darker smoke indicates motor oil in the exhaust, which means that one (or more) cylinders have a broken ring, and the engine needs a ring job.
Fix for white smoke: replace head gasket.
Fix for black smoke: ring job.
Oct 05, 2011 | 2003 Lexus ES 300
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
271 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
