Question about RCA RP5610 Clock Radio
How to install time - RCA RP5610 Clock Radio
  • RCA Master
  • 5,387 Answers
Press and hold Set until a little clock is displayed. Then use the forward/reverse buttons to change the time (you will see A.M. and P.M. indicators). The buttons are all on the right side of the clock radio. Then press Set again to leave the time set area. As you press Set again, you will be able to set the alarm time (Wake 1 and Wake 2) by pressing the forward/reverse buttons as well.
If any icon is flashing, press Set repeatedly until they stop.
I hope this helps.
Posted on Aug 23, 2010
How to set valve timing on the 1990 3.0 cressida
To install:
  1. Install the oil pump drive gear and tighten the 16 ft. lbs. (22 Nm).
  2. Using a suitable seal installer, install a new crankshaft timing gear seal. Install the gear.
  3. Temporarily install the idler pulley and tension spring.
  4. If using the old belt, check the rotation direction chalk mark placed on the timing belt during disassembly.
  5. Install the timing belt on the crankshaft pulley.
  6. Install the lower timing belt cover, air conditioning idler pulley bracket, compressor bracket and the lower timing belt cover retaining bolts and nuts. Install the pollution system air pipe assembly.
  7. Install the crankshaft pulley and pulley retaining bolt and torque to specification.
  8. Turn the crankshaft pulley and align its groove with the 0 mark on the lower timing belt cover.
  9. Install the camshaft timing pulleys and timing belt as follows:
    1. Turn the crankshaft pulley and align its groove with the 0 mark on the No. 1 timing belt cover. If the engine has not been disturbed, the engine should still be in this position.
    2. Align the alignment marks on the camshaft timing pulleys and the No. 2 timing belt cover. Install the timing pulley.
    3. Install the straight pin into the hole.
    4. When replacing the camshaft or the camshaft timing pulley. Always align the center holes of the camshaft and timing pulleys and insert the straight pin. When reusing the camshaft or camshaft timing pulleys, check that the straight pin hole position is in the same position it was at disassembly, insert the straight pin. Install the plate washer and pulley bolt.
    5. Using a suitable camshaft pulley holding tool, hold the pulley and tighten the pulley bolts to 36 ft. lbs. (49 Nm).
    6. Check that the matchmarks on the camshaft timing pulley are aligned with those on the No. 2 timing belt cover.
    7. Install the timing belt to the intake camshaft timing pulley, the exhaust camshaft timing pulley and the idler pulley.
    8. Loosen the idler pulley mount bolt until the pulley is moved slightly by the spring tension. Tighten the idler pulley mount bolt to 36 ft. lbs. (49 Nm).
    9. Check that the timing belt tension is equal all the way through. Turn the crankshaft pulley 2 revolutions clockwise from TDC to TDC.
    10. Check that the alignment marks on the camshaft timing pulleys are aligned with those on the No. 2 timing belt cover.
    11. If the marks do not align, remove the belt and install it again.
    12. Install the No. 3 timing cover gasket, cover and retaining bolts.
    13. Install the power steering pump belt.
    14. Install the four bolts, fan clutch, water pump pulley and fan shroud.
    15. Install the fan shroud mounting nuts.
    16. Tighten the fan belt adjusting bolt and nut of the power steering pump.
    17. Install the 4 bolts to the fluid coupling (fan clutch) flange.
  10. Install the air conditioning drive belt.
  11. Install the thermostat and water outlet along with it retaining bolts.
  12. Install the spark plugs and spark plug wires.
  13. Install the radiator assembly along with the radiator hoses.
  14. Install the drive belts and adjust as necessary.
  15. Install the air cleaner case assembly with the air intake connector.
  16. Refill the coolant system.
  17. Reconnect the negative battery cable. Connect a timing light and tachometer.
  18. Start the engine and set the ignition timing. Recheck the idle speed adjustment. Check for leaks and add coolant as necessary.
Aug 20, 2017 | Cars & Trucks
How do I set timing on a 2.3 Suzuki aerio engine
wow no job stated.
04 (2.3L) ill take a wild guess and say, you might be fiddling the cam
and doing something there, new cam, new lifters, new chain, new head, ? what?
FSM means factory service manual, ever heard of one?
the FSM is just lousy 4 bucks why not read that first. and not mess it up.
https://suzukipitstopplus.com/Products/1004-2004-aerio-service-manual.aspx
you said SET, so i can only assume its all apart. right then
you want to Instal the chain and time it, right so here are the fsm steps
no photos. log in and read the FSM for that.
  1. Check that match mark on crankshaft timing sprocket is in match with timing mark on lower crankcase.
  2. Install crankshaft timing sprocket as shown in figure.
  3. Apply oil to bush of idler sprocket and install idler sprocket and sprocket shaft.
  4. Install first timing chain by aligning dark blue plate of first timing chain and match mark on idler sprocket.
  5. Bring yellow plate of first timing chain into match with match mark on crankshaft timing sprocket.
  6. Apply engine oil to sliding surface of timing chain tensioner and then install it as shown in figure. Tighten tensioner nut to 18 ft. lbs. (25 Nm).
  7. With latch of tensioner adjuster No.1 returned and plunger pushed back into body, insert stopper into latch and body. After inserting it, check to make sure that plunger will not come out.
  8. Install timing chain tensioner adjuster No.1. Tighten the timing chain tensioner adjuster No. 1 bolt to 8 ft. lbs. (11 Nm).
  9. Pull out stopper from adjuster No.1.
  10. Apply engine oil to sliding surface of timing chain guide No.1 and then install it. Tighten guide bolts to 6.5 ft. lbs. (9 Nm).
  11. Check that dark blue and yellow plates of first timing chain are in match with match marks on sprockets respectively.
  12. Install second timing chain as follows:
    • Check that match mark on crank timing sprocket is in match with timing mark on lower crankcase.
    • Check that arrow mark on idler sprocket faces upward.
    • Check that knock pins of intake and exhaust camshafts are aligned with timing marks on cylinder head.
    • Install second timing chain by aligning yellow plate of second timing chain and match marks on idler sprocket.
    • Install sprockets to intake and exhaust camshafts by aligning dark blue plate of second timing chain, match marks on intake sprocket and exhaust sprocket respectively. NOTE As an arrow mark is provided on both sides, camshaft timing sprocket has no specific installation direction.
  • Install intake and exhaust camshaft timing sprocket bolts. To install it, fit a spanner to hexagonal part at the center of camshaft to hold it stationary. Tighten the camshaft timing sprocket bolt to 57.5 ft. lbs. (80 Nm).
  • Push back plunger into tensioner body and hold it at the position by inserting stopper into body.
  • Install timing chain tensioner adjuster No.2 with new gasket. Tighten the timing chain tensioner adjuster No. 2 bolts to 8 ft. lbs. (11 Nm) and No. 2 nut to 33 ft. lbs. (45 Nm).
  • Pull out stopper from timing chain tensioner adjuster No.2.
  • Turn crankshaft two rotations clockwise then align timing mark on crankshaft and timing mark on cylinder block.
  • Check that timing marks of cylinder head and cylinder block are in match with match marks on sprockets respectively.
  • Apply oil to timing chains, tensioner, tensioner adjusters, sprockets, and guides.
  • Install timing chain cover. Reverse removal sequence to install timing chain cover noting the following points:
    • Apply sealant "A" and "B" to area as shown.
      • "A": Sealant 99000-31250
      • "B": Sealant 99000-31140
    • Apply sealant amount to the following areas.
      • "a": 0.12 inches (3mm)
      • "b": 0.08 inches (2mm)
      • "c": 0.24 inches (6mm)
      • "d": 0.63 inches (16mm)
      • "e": 0.55 inches (14mm)
      • "f": 2.56 inches (65mm)
      • "g": 2.87 inches (73mm)
      • "h": 0.16 inches (4mm)
    • Apply engine oil to oil seal lip, then install timing chain cover. Tighten bolts and nut to 8 ft. lbs. (11 Nm).
      NOTE Before installing timing chain cover, check that pin is securely fitted.
    • Before installing timing chain cover, check that pin is securely fitted.
  • Install alternator belt idler pulley. Tighten nut to 30.5 ft. lbs. (42 Nm).
  • Install alternator belt tensioner. Tighten bolts to 18.5 ft. lbs. (25 Nm).
  • Install water pump pulley.
  • Install A/C compressor bracket (if equipped). Tighten bracket bolts to 40 ft. lbs. (55 Nm).
  • Install cylinder head cover with new gaskets and seal washers and tighten nuts to 8 ft. lbs. (11 Nm).
  • Install oil pan.
  • Install crankshaft pulley using pulley holder tool. Tighten the crankshaft pulley bolt to 108.5 ft. lbs. (150 Nm).
  • Install engine assembly.
  • Install all remaining components in the reverse order of the removal procedure.
did that cover it, surely not.
but if you get the FSM and read it or log in , you will not miss the photos and the complex sealing bs on this motor.
Oct 18, 2014 | 2004 Suzuki Aerio
99 kia sporage timing marks
Hi there:
Check this information...
Crankshaft match marks
Align marks on timing belt pulley and pump body.
Camshaft pulley alignment marks
  1. Align marks on camshaft pulleys with alignment marks on seal plate.
  2. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  3. Loosen tensioner lock bolt.
  4. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  5. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  6. Apply a force of 22 lbs to timing belt between camshaft sprockets.
  7. Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  1. NOTE: Replace tensioner spring if timing belt deflection is excessive.
  2. Timing Belt Installation
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 14, 2012 | Kia Sportage Cars & Trucks
Problem with 99 kia
Hi there:Check this information...
Can we install a a ptg 74pvp tankless hot water heater in a closet? Would we need to install grating in the closet wall to provide more fresh air?
Rheem Tankless Water Heater Selection and Installation Videos
  • Introduction - time 04:11
  • Pre-Qualifying the installation - time 01:13
  • Selecting the Right Product - time 01:48
  • Key Differences Between Tankless & Storage Heater- time 01:27
  • Choosing the Location - time 01:20
  • Installation: Major Components - time 00:58
  • Installation: Tools Required - time 00:48
  • Installation: Mounting the Heater - time 01:15
  • Installation: Plumbing & Gas Connections - time 04:29
  • Installation: Side Wall Vent Termination - time 02:41
  • Outdoor Installation - time 01:21
  • Connecting the Remote Control - time 01:42
  • Turning on the Water Heater - time 01:00
  • Commercial vs. Residential Products - time 01:47
  • Manifolding Multiple Units - time 01:43
  • Troubleshooting & Additional Support - time 01:01
Feb 02, 2011 | Rheem Tankless Hot Water Heater...
Como poner la banda de tienpo de un toyota camery
Installation
1.Install No. 2 idler pulley (if removed). Install and tighten bolt to specification. See TORQUE SPECIFICATIONS . Ensure idler pulley is clean and rotates smoothly. 2.Install No. 1 idler pulley and tension spring (if removed). Pry No. 1 idler pulley away from timing belt area as far as possible. Temporarily tighten No. 1 idler pulley bolt. Ensure idler pulley is clean and rotates smoothly. 3.Using crankshaft pulley bolt, rotate crankshaft so timing mark on crankshaft sprocket aligns with timing mark on oil pump housing. See. This will position keyway in crankshaft sprocket at 12 o'clock position.
CAUTION:If reusing timing belt, ensure reference marks on timing belt align with reference marks placed on crankshaft and camshaft sprockets. Ensure timing belt is installed in original direction of rotation.
4.Ensure all sprockets and idler pulleys are clean. Install timing belt on crankshaft sprocket, oil pump sprocket, No. 1 idler pulley, and then No. 2 idler pulley in sequence. 5.Install timing belt guide with cupped side away from crankshaft sprocket and flat side toward timing belt. Install No. 1 timing belt cover and new gasket. 6.Align crankshaft pulley key groove with key in crankshaft. Install crankshaft pulley. Install and tighten crankshaft pulley bolt to specification. 7.Rotate crankshaft clockwise so cylinder No. 1 is at TDC on compression stroke. Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover. If reusing timing belt, ensure reference mark on timing belt aligns with upper edge of No. 1 timing belt cover. 8.Rotate camshaft, and align hole in camshaft sprocket with alignment mark on camshaft bearing cap. See Fig. 2 . Install timing belt on camshaft sprocket. If reusing timing belt, ensure reference mark on timing belt aligns with the reference mark on camshaft sprocket. Ensure tension exists on timing belt between the crankshaft and camshaft sprockets.
CAUTION:DO NOT rotate crankshaft counterclockwise, as viewed from timing belt end of engine.
9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence.
Dec 23, 2010 | 1993 Toyota Camry V6
Need diagram to put timingbelt on 2001 kia sportage
prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
  1. Disconnect battery negative cable.
  2. Remove fresh air duct.
  3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
  4. Remove upper radiator hose.
  5. Remove fan clutch assembly bolts.
  6. Remove 5 cooling fan shroud bolts.
  7. Remove fan shroud and fan as an assembly.
  8. Loosen alternator mounting bolts and remove drive belt from pulley.
  9. Remove fan pulley.
  10. Remove 4 cooling fan assembly bolts.
  11. Remove cooling fan assembly.
  12. Remove 4 bolts and upper timing belt cover.
  13. Remove 2 lower bolts and lower timing belt cover.
  14. Loosen adjusting bolt and remove A/C belt.
  15. Remove alternator belt.
  16. Loosen power steering pump lock bolt and mounting bolt.
  17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
  18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  19. Remove 5 bolts and remove damper.
  20. Remove timing belt guide from timing belt pulley.
  21. Loosen tensioner lock bolt.
  22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
  23. Remove timing belt.
To Install:
NOTE: Timing belt pulley timing mark and timing mark must be aligned.
NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
  2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
    Do not turn crankshaft counterclockwise.
  3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
  4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
  5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
    • Deflection should measure 0.43-0.51 inch (11-13 mm)
    NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
  6. Install timing belt guide.
  7. Install crankshaft damper pulley.
  8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
  9. Install power steering pump drive belt.
  10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
  11. Install alternator drive belt.
  12. Install A/C drive belt.
  13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
  16. Install fan pulley.
  17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
  18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
  19. Adjust alternator belt tension and tighten alternator mounting bolts.
  20. Install upper radiator hose.
  21. Install fresh air duct.
  22. Connect battery negative cable.
  23. Refill/bleed cooling system.
DOHC To Remove:
  3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
  4. Remove 4 thermo-modulated fan shroud fasteners.
  5. Remove generator drive belt.
  6. Remove fan pulley (located above crankshaft pulley).
  7. Remove 4 bolts and splash shield (located under front of vehicle).
  8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
  9. Remove 5 bolts and upper timing belt cover.
  10. Remove 2 bolts and lower timing belt cover.
  11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
  12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
  13. Remove timing belt.
To Install:
  1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
  2. Align marks on camshaft pulleys with alignment marks on seal plate.
  3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  4. Loosen tensioner lock bolt.
  5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
    • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
  8. Install lower timing belt cover.
  9. Install upper timing belt cover.
  10. Install power steering drive belt and adjust belt tension.
  11. Install fan pulley.
  12. Install generator drive belt and adjust belt tension.
  13. Install A/C drive belt and adjust belt tension.
  14. Install splash guard.
  15. Install fan and fan shroud.
  16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  17. Install fan shroud mounting bolts.
  18. Install fresh air duct.
  19. Connect hose to resonance chamber.
  20. Connect battery negative cable.
Aug 02, 2010 | 2001 Kia Sportage
I need a timing chain diagram for a 2002 jeep grand Cherokee with a 4.0L engine
This is the procedure on it.
spacer.gif 2008-10-22_161446_1.thumb.gif spacer.gif spacer.gif View Full Image spacer.gif
INSTALLATION
NOTE: Assemble the timing chain, crankshaft sprocket and camshaft sprocket with the timing marks aligned Fig. 5 .
  1. Apply Mopar(TM) Silicone Rubber Adhesive Sealant to the keyway in the crankshaft and insert the key With the key in the keyway on the crankshaft, install the assembly on the crankshaft and camshaft.
spacer.gif 2008-10-22_161528_2.thumb.gif spacer.gif spacer.gif View Full Image spacer.gif
Install the camshaft sprocket retaining preload bolt and washer Fig. 6 . Tighten the preload bolt to 108 N.m (80 ft. lbs.) torque.
spacer.gif 2008-10-22_161605_3.thumb.gif spacer.gif spacer.gif View Full Image spacer.gif
  • To verify correct installation of the timing chain, turn the crankshaft to position the camshaft sprocket timing mark as shown in Fig. 7 . Count the number of chain pins between the timing marks of both sprockets. There must be 15 pins. NOTE: Installation of the timing chain with the timing marks on the crankshaft and camshaft sprockets properly aligned ensures correct valve timing. A worn or stretched timing chain will adversely affect valve timing. If the timing chain deflects more than 12.7 mm (1/2 inch) replace it. The correct timing chain has 48 pins. A chain with more than 48 pins will cause excessive slack.
  • Install the crankshaft oil slinger.
  • Replace the oil seal in the timing case cover.
  • Lubricate the tension spring, thrust pin and pin bore in the preload bolt with Mopar(TM) Engine Oil Supplement, or equivalent. Install the spring and thrust pin in the preload bolt head Fig. 6 .
    spacer.gif 2008-10-22_161701_4.thumb.gif spacer.gif spacer.gif View Full Image spacer.gif
  • Install the timing case cover and gasket.
  • With the key installed in the crankshaft keyway, install the vibration damper, washer and bolt. Lubricate and tighten the bolt to 108 N.m (80 ft. lbs.) torque.
  • Install the serpentine drive belt and tighten to the specified tension, Refer to Engine/Drive Belts, Mounts, Brackets and Accessories/Drive Belt/Service and Repair for the proper procedure.
  • Install the fan and hub (or Temporal fan) assembly. Install the shroud.
  • Connect negative cable to battery
  • Jul 16, 2010 | Jeep Grand Cherokee Cars & Trucks
    1999 kia sportage timing marks
    dfd3ea1.gif Crankshaft match marks
    8. NOTE: Replace tensioner spring if timing belt deflection is excessive.
    Jul 26, 2009 | 1999 Kia Sportage
    Need instructions to replace 1993 Toyota Camry Timing Belt
    Hi Kmcarroll77
    TIMING BELT REPLACEMENT - 2.2L -1993 Toyota Camry
    Installation
    9.Loosen No. 1 idler pulley bolt 1/2 turn. Rotate crankshaft pulley 2 full revolutions clockwise from TDC to TDC. 10.Ensure timing mark on crankshaft pulley aligns with "0" mark on No. 1 timing belt cover, and hole in camshaft sprocket aligns with alignment mark on camshaft bearing cap. See Fig. 2 . If timing marks are not aligned, remove timing belt and reinstall. 11.Rotate crankshaft clockwise 1 and 7/8 revolutions and align crankshaft pulley "0" mark with 45-degree Before Top Dead Center (BTDC) mark on No. 1 timing belt cover. See Fig. 5 . 12.Tighten No. 1 idler pulley bolt to specification. See TORQUE SPECIFICATIONS . Install No. 2 timing belt cover and gaskets. Install and tighten spark plugs to specification. 13.To install remaining components, reverse removal procedure. Install all bolts/nuts on right (timing belt side) engine mount before tightening to specification. 14.On Camry, when installing control rod and bracket on strut tower and right (timing belt side engine mount, tighten bolts to specification in sequence. See Fig. 6 . On MR2, tighten engine
    Hope this helps, don't forget to rate.
    Lazaruselite
    Feb 25, 2009 | 1993 Toyota Camry V6
    RCA RP5610 Clock Radio Logo
    146 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
