Question about Mantis 2-Cycle Tiller
Weak compression - Mantis 2-Cycle Tiller
  • 885 Answers
Loose spark plug, rings and/or cylinder scratched/scuffed (it doesn't take much) or hole in piston.
Posted on Aug 23, 2010
Tip
How to diagnose a cylinder misfire
First do a compression test on that cylinder to verify there is no internal engine problems and compression on the misfiring cylinders is the sameas the other cylinders. If compression is good verify spark on that cylinder is as good as the spark on the other cylinders if not replace the spark plug and wire, if spark is still weak replace coil. If problem is still no or weak spark then you have a wiring problem on that cylinder. If spark is good use a LED testlight to verify the circuit has good power and ground pulsating on the injector circuit, if not you have a wiring problem if the circuit is working like it should replace the injector. If everything is good up to this point you likely have a leaking intake manifold gasket.
on Dec 01, 2009 | Cadillac STS Cars & Trucks
Hillux d4d 2.7 no start
ahhhh a diesel, that , is a horse of a different color.
not GAS but oil burner engine.! there is no spark on diesels...
it uses huge compression rates to combust.
1: glow plugs dead. (or its controls)
2: low compression,
3: bad fuel ,old fuel , water in fuel.
4: weak battery. old or weak for any reasons. cranks too slow.
5: if EFI , other complex reasons. direct injection is it?
Jan 21, 2014 | 2012 Toyota Sienna Base 7-Passenger...
P0300
which engine? there are many.
can be 50 things
300 means random misfire on all cylinders.
it really means all cylinder have weak HP, weak power, weak combustion energy levels !
The ecu actually measures crankshaft acceleration rates (geekspeak)
in lay terms this means (btw 300s never lie, it's REAL misfire)
there is one exception a loose timing belt or cam chain. can trip 300s.
in no order ever.
1: bad spark to all cyl.
2: low compression to all cylinders (cam timing off, melted CAT)
3: bad fueling to all. (EGR stuck wide open , engine stalls?)
but can be 50 things, so its best not to GUE$$
what we do is conduct simple tests.
first is do the 60,000 mile tuneup. do that its cheap, and works in most cases.
1: tuneup time.sparks and filters both. fuel and air.
2: compression test, and vacuum tests. at WOT,. both. ask for data.
3: check cam timing. if compression fails on all cyl.
4: i scan the ECU looking at fuel trim and closed loop working, ask.
Jan 19, 2014 | Toyota RAV4 Cars & Trucks
I have and echo bp250 runs but has no power change carb but didn't help is there something iam missing
Hello Margaret,
I would purchase a compression tester from a local parts store and check compression. They simply screw into the spark plug threads, then you pull on the starter rope a few times and observe the reading. You should have at least 60 psi of compression. If compression is good, I would then check spark. Spark testers are fairly cheap and are available at your local parts store too. If you just replaced the carb, Im willing to bet you will find your answer with the two solutions I mentioned. If spark is weak, the coil can be adjusted closer to the flywheel. If compression is weak, your probably looking at a new cylinder/piston and may not be worth fixing. Hope this helps. Good luck and happy wrenching!
Sep 18, 2013 | Echo Pb - 413t Backpack Blower
Low power ford escort 1994, weak on hills
325,000 miles,, jeez,,,, need a rebuild on that engine. You walk that far and tell me how you feel, worn out im guessing. new set of rings and bearings and give the poor thing its bang back. give it a compression test to confirm but my moneys on low compression ie old engine
Jan 17, 2013 | 1994 Ford Escort
Timeing for LT1050 I have way too much compression!!!!
there is a compression release on the cam but make sure you have a strong battery a weak battery will act like like a compression problem
May 09, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
What should a 98 dodge 5.2 compression be. Its in a 1500 Ram if that makes a difference.
GOOD COMPRESSION SHOULD BE 120 - 175 PSI IF COMPRESSION 100 PSI ACCEPTABLE. 90 PSI LOWER CYLINDER WEAK IF COMPRESSION 50 - 20 BLOWN HEAD GASKET.
Jul 05, 2011 | 1999 Dodge Ram
The Stihl 038 super won't start. It is getting too much gas on the spark plug when I try to crank it. Just replaced the carb hoping it was that but still it won't start. The saw was working fine a...
hi there mwb15
have you made sure the ignition coil is producing enough voltage to fire under compression load ?
you may get a spark at the plug unloaded but under load it may be breaking down / weak making you think its got a fuel problem ?
does your system use a cdi coil system or point/condenser system ?
spark usually falls into weak spark, no spark catergory
if compression , fuel ( you replaced carb) and exhaust are ok , and you have air and vaccuum tight c/cases only things left are timming and spark
remember F A C T S
F = Fuel A = Air & ( air tight c/cases ) C = Compression T = Timming S = Spark
compression should be about 130- 140 approx if in good running order
take a look and let me know
cheers pauly46
Jun 18, 2011 | Garden
Mantis 2-Cycle Tiller Logo
134 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
