Question about Siemens optiset E Corded Phone
No mute key on siemens optiset phone...what is keyboard combination to mute a call?
  • jeanette_reb Oct 14, 2010
    Try *6 to mute.
  • Anonymous Oct 14, 2010
    Try *6 to mute.
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
How to put the phone on mute
Your phone must have MUTE buttton.
Dec 15, 2015 | Siemens optiset E Corded Phone
I see the "at" key on my keypad but i can not use it what is the combination? so i can't send any emails?
If you have a standard US keyboard, you hold down the shift key and press the key with the @ symbol at the SAME TIME.
Sep 12, 2013 | Fujitsu Siemens LifeBook S7110 Notebook
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
How to turn on wireless
Many laptops have a switch on the case that is for turning on the wireless function. In fact, some even have a light that goes on indicating that the wireless is working. Look for that switch on the front or side of your case,
Another way wireless is turned on or off is by a combination of keystrokes using the Fn key (lower left side of the keyboard) and one of the special function keys at the top of the keyboard. This key is usually identified by an icon representing a radio tower. By pressing this combination, the wireless function will be turned on or off.
Hope this helps.
Oct 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
After cleaning my keyboard ther sound on my laptop has gone mute; I think I accidetly pressed some key combination that has muted the sound
the key combination should be something like fn+f10 to mute and unmute. Let me know the model # of the laptop so i can assist you further if that doesn't work.
Sep 14, 2009 | Computers & Internet
My speakers do not work
The Dell has a "Fn" key. The "Fn" used with other keys control special features. I have a Dell keyboard here, on it holding the "Fn" and pressing "End" will alternately mute/unmute the speakers. "Fn" + "Page up" will raise volume, "Fn" + "Page down" will lower. You may have the volume muted, or turned all the way down.
The keyboard I have is from an 1100, your "Fn" key combinations may vary from mine.
Jan 02, 2009 | Dell Latitude D600 Notebook
Cant seem to find how i change the display name on my Opti500
Usually changed by your Siemens system programmer.
Can be changed by the customer using Manager C software or by using an optiset E Memory Handset.
Nov 12, 2008 | Siemens optiPoint 500 Standard Corded...
No ringing tone or incoming call sounds.
The primary phone sets the ring for all phones. If it is off, nothing will ring. Once it is on you may set the volume of the rings on all sets individually. If you have the manual, look under Ringer Off on the main set. Hope this helps, let me know
Feb 18, 2008 | Siemens optiset E Corded Phone
Siemens optiset E Corded Phone Logo
2,401 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
