Question about Samsonite Tripod
By mistake i have locked my american tourister luggage bag and now i can't open it, i forgot the 3 digit combinations. please tell me solution how i can unlock it
  • 12 more comments
  • arun soman
    arun soman Jan 23, 2016
    good it will work
  • Swathi2
    Swathi2 Apr 18, 2016
    It worked superbly
  • deepak kumar Oct 24, 2016
    lock problem please. call me 8890073536
  • technical world
    technical world Mar 04, 2017
    What if there is no holes???!
  • Amit Rohela
    Amit Rohela Mar 26, 2017
    It worked man Thanks a lot
  • Amit Rohela
    Thanks Man it worked, 3rd time it opened up.
  • bhagirathsinh sisodiya
    bhagirathsinh sisodiya Apr 27, 2017
    Thanks a lot, it worked for me...
  • ria roy Jun 26, 2017
    i have skybag trolly there is no such holes...and now i forget my 3 digit number combination..what should i do..please help me out
  • Thomas Jul 28, 2017
    I have the same problem. But none of the answers helped me. My case bought 2017
  • Ayan Bose
    Ayan Bose Aug 11, 2017
    It's simple actually. Check for screws inside of your bag and unscrew them which is holding the lock on outside. Once unscrewed you will have the lock in your hand. Roll your numbers to check 3 numbers having grooves in same position and allows the unlock grooves fit in. Once you have got the 3 numbers grooves allowing the unlock button fit in, check the combination number it allowed. There you go, now you know your combination lock number. This method is for locks which do not have a reset button on outside of the lock.
  • Pravinkumar Dec 04, 2017
    lock problem 7760255278
  • Abhijeet Sahu
    Abhijeet Sahu Dec 27, 2017
    Thank you Mr.Ayan Bose, But my suitcase is already locked. Any solution?
  • Bhanwar Singh Parmar Jan 18, 2018
    lock combination problem plz call 9770710669
  • Pratibha May 07, 2018
    Not getting how to unlock ??
    New Friend:
How to Unlock an American Tourister Suitcase's Number Lock
<b>• Place the suitcase right side up and look at every number wheel to find a hole at the bottom.
• Bring the holes of the three wheels in the same position.
• Now keep holding the button as to unlock and rotate the 1st wheel and reduce its number by 1.
• Repeat the same process with the rest of the two wheels.
• Again start with the 1st wheel and reduce another 1 position.
• Attempt the whole process for the third time and your suitcase will get unlocked.
</b>
Posted on Sep 17, 2014
  • 31 more comments
  • Ananya Datta
    Ananya Datta Oct 23, 2014
    Thanks a lot for this.... :) :)
  • Manisha Aditya
    Manisha Aditya Nov 30, 2014
    thanks buddy. saved a lot of troubles :)
  • k.sharat Babu
    k.sharat Babu Mar 04, 2015
    thanks buddy, very much helpful and is working superb
  • gaurav Mar 14, 2015
    thanx buddy it's superb...
  • Prashant Pant
    Prashant Pant Aug 16, 2015
    Excellent man.. It worked.. Thanks for the hack..
  • Sreemoyee Majumder
    Sreemoyee Majumder Sep 16, 2015
    thankx a lot.. u hv saved my day.. itz superb and it worked..thankx again..:) :) love from india..:) :)
  • Padmanabhan AR
    Padmanabhan AR Oct 19, 2015
    I have been struggling for few months.Thanks a lot.It works nicely
  • Manissha
    Manissha Oct 20, 2015
    Great idea...Saved a lot of time . Thanks a lot :)
  • Komal Shamihoke
    Komal Shamihoke Nov 09, 2015
    this trick was not much of help.... Basically I went through all combinations starting 000, 001 ,002 etc.
  • Rajan Ramaswami
    Rajan Ramaswami Mar 27, 2016
    Thank You, Soumya Bose. Your suggestion worked with the lock in our American Tourister combination lock. Just to be clear this lock is attached/glued to the suitcase. No TSA002 diesignation.
    Couple of key points to note:
    We found out was that the holes are visible when more than one number is selected. The holes show up in the center, left of the slot.So, we selected the numbers such that the holes are lined up in the same orientation ( in our case left of center of slot).
    We also started with the suggested sequence with the number that is farthest from the latch. It might have worked starting with the number closest to the latch, but we do not know!
  • Babulal Dholpure
    Babulal Dholpure Apr 23, 2016
    It was a great help, it took me 40 seconds to execute it after reading your help.
    God Bless you
  • Narsimha
    Narsimha Nov 18, 2016
    Super Man. Thank you so much.
  • Aravind C SasiKumar
    Aravind C SasiKumar Dec 02, 2016
    Thank you man. It's working.
  • Vishwavardhan Damaraju
    Vishwavardhan Damaraju Dec 04, 2016
    Great suggestion it worked !
  • Ashish Arora
    Ashish Arora Dec 17, 2016
    Worked like charm! Thank you so much for this!
  • Prasannah Ganeshan
    Prasannah Ganeshan Jan 21, 2017
    This is one of the best. I would have almost broken the lock. Thanks for the suggestion.
  • technical world
  • Surya Rout
    Surya Rout Mar 06, 2017
    Thankyou. It worked perfectly. Lots of thankx again.
  • Anindita Mondal
    Anindita Mondal Mar 08, 2017
    Lots of thanks!!!
  • Prashanth Saligram
    Prashanth Saligram Apr 13, 2017
    Thanks bro...
  • Elle Wires
    Elle Wires May 12, 2017
    Great..a bit hard to notice the hole but works perfect once u see it
  • Elle Wires
  • ankush sood
    ankush sood May 24, 2017
    Wow, amazing worked for me as well
    Thanks a lot
  • Caqwr
    Caqwr May 29, 2017
    It actually works
  • aishwarya sekar
    aishwarya sekar Jun 03, 2017
    Worked..thank you so much
  • Sunil kumar Jul 17, 2017
    If both three wheel are same number hole align . this type lock how could open
  • Prateek Sharma
    Prateek Sharma Jul 22, 2017
    Worked for me. Thanks
  • Kapil Jambhulkar
    Kapil Jambhulkar Sep 11, 2017
    Thanks. It worked...
  • Monika Siragam
    Monika Siragam Nov 05, 2017
    Thank you, Soumya Bose. It worked.
  • Raj Mohan
    Raj Mohan Feb 17, 2018
    Thanks alot.. It worked
  • Narayan Sadhuka
    Narayan Sadhuka Mar 14, 2018
    This method earlier worked for me several times, but this time it didn't, i don't know why. :(
  • Narayan Sadhuka
    So is there any other such solution if this one does not work?
  • lhee cho
    lhee cho Apr 04, 2018
    Pls help me i mistaken set the lock code of my luggage american tourister..now i cannot open it..im using the curio spinner luggage..pls help me to open it..thank u
    New Friend:
What do you mean by "hole"? Where should i see a hole? Thank you
Posted on Jun 14, 2016
    New Friend:
Thanks very much , it worked ????
Posted on Mar 27, 2016
    New Friend:
Help I got an American tourister 10 years ago and can't remember the code
Posted on Jul 03, 2017
    New Friend:
  • 3 Answers
You can try 999 combinations but it's time consuming. Easiest way is to use a very fine blade with pointy tip and insert on right side of number wheel. Each wheel has a smaller wheel next to number wheel which is not visible. Now turn wheel and when you feel blade has pushed in make a note of the front number. Do the same to other two wheels. Let's say you got code 123, so to open it code will be 678. Basically opposite numbers, if you write it on a piece of paper numbers 0-9 you will be able to find opposite numbers.
Posted on Apr 08, 2017
It worked for me thankuuuuu :D
Posted on Apr 08, 2018
Posted on Aug 11, 2017
    New Friend:
  • 3 Answers
Thanks buddy it worked for me as well
  • Samsonite Master
  • 5,412 Answers
This forum is for Photographic monopods and tripods. I believe there is a forum dealing with hand luggage. You may find more help there.
Posted on Sep 09, 2016
    New Friend:
Thanx yaar
Posted on Sep 01, 2016
    New Friend:
@asiqifthikar
it worked thank u very much, but instead of hammer u can hit it with ur 1 finger knuckle since its delicate(for hammer).
I Just signed in to fixya to say u THANKS.
Posted on Jul 09, 2016
    New Friend:
Thank you very much
Posted on Jul 06, 2016
    New Friend:
Great. It worked. I tried calling customer service and everything. Takes a while but works
Posted on Apr 18, 2016
    New Friend:
Thanks my wife able to open lock thanks save my efforts
Posted on Oct 17, 2015
  • 1 more comment
  • Manmohan Pandey
    Manmohan Pandey Nov 23, 2015
    Thanks a lot . am am able to open lock .I called to customer care but he did not help .
  • Aditya Sharma
    Aditya Sharma Dec 27, 2016
    Works like charm thank you!
    i have skybag..there is no such holes..what should i do
4 Suggested Answers
SOURCE: forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Posted on Dec 10, 2009
  • 5 Answers
SOURCE: can not open a american tourister suitcase
Hit the nail with a hammer to all the sides and remove it after 5 mins....
Posted on Dec 24, 2009
SOURCE: change luggage key combination
I had the same problem, basically I went through all combinations starting 000, 001 ,002 etc. Ok it took a couple of hours, my fingers were sore but cheaper than buying another one !
Posted on May 26, 2008
I have got a new american tourister trolly bag. The unlock key was 000 but its not unlocking my bag. What should i do ?
That is common problem on american tourist er luggage. You cheek your luggage note book and check security system. I think you find some idea. Are you want to new luggage for you and that is very comfortable for you visit this site and get many Idea about luggage. Best Luggage Sets Top Models For 2017 To Start Traveling .I follow this site after 2 years and get many idea about luggage.
Nov 02, 2017 | Luggage & Travel
Is first bag free
To both questions, "It depends on the airline."
While there are standard baggage sizes across some of the major carriers, it is prudent to check the airline you will be traveling upon regarding luggage fees, size allowances, and just what can be carried on and what must be checked. Plus, you have to know what you may carry in carryon luggage, what you can not take, and what can not be carried in checkin luggage. And weight is a factor as well.
Aug 22, 2017 | Luggage & Travel
By mistake I have locked my american tourister luggage bag and now I can not open it I forget the 3 digit combinations. How I can unlock it
Few standard combination locks are machined to such a high degreee of precision that when the lock is put under strain one or more of the numbered rotating dials is not left a little loose while the other(s) become tight.
It is a matter of slowly turning the tight dial or barrel until it becomes loose. At this point the lock will move a little as long as it is kept under strain and one of the other numbered barrels that was previously a little loose will become tighter and so it is time to slowly turn this barrel and repeat until the lock releases.
Practice on something like a cheap cycle lock and you will discover the trick that is increasingly difficult as the quality of the lock improves.
It takes a light touch and lots of patience. So far I have even opened a quite expensive combination padlock this way but it relies on imperfect manufacture. It would be quite impossible to use the technique on a perfectly made combination lock.
Oct 02, 2016 | Locks & Locksmithing
By mistake I have lock.my american tourister trolly lock
If you have never set the 3 digit lock code the default lock code from the factory is 0-0-0
Aug 03, 2016 | Photography
It's locked and everything imp like my clothes atm etc is inside I am using this bag for first time but it's not opening up
Dial the three wheels to 0-0-0, which is the default combination setting for American Tourister and Samsonite luggage.
Try this setting
Feb 24, 2016 | Vacuums
Bolt cutters?
REPLACEMENT PARTS
Certain replacement parts are available for purchase, along with a small shipping charge through Consumer Relations. These include: Keys; Padlocks for Softside Luggage; ID Tags; and Detachable Shoulder Straps.
Order Replacement Parts: 1-800-262-8282 (Monday-Friday 9:00 AM - 6:00 PM EST)
Service Repairs Samsonite
Jan 08, 2016 | Locks & Locksmithing
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    I HAVE FORGOTEN THE CODE COMBINATION OF vip LUGAGE TROLLEY BAG SO PLEASE HELP
    Please check out this page: http://www.vipbags.com/support/luggage-care-faqs
    VIP provides assistance if you forgot your combination code. If this is not an option, first try all the combination, 000, 001 etc. Birth dates, last/first three digits of your phone number, car number etc. If this is not an option either, take it to the luggage seller, they can break the lock. If everything else fails, then you need to cut it open.
    Oct 29, 2012 | Cell Phones
    Photography Logo
    62,490 people viewed this question
    Top Samsonite Photography Experts
    timtak
    Level 1 Expert
    Marvin
    Marvin
    Are you a Samsonite Photography Expert? Answer questions, earn points and help others
