Question about Dishwashers
Powerpoint dishwasher IDW12 ERROR CODE E3 - Dishwashers
3 Suggested Answers
SOURCE: Dishwasher problem powerpoint IDW12
clean the filter on the intake pipe, just done mine.
Posted on Dec 02, 2008
mrsno
  • 166 Answers
SOURCE: Powerpoint dishwasher IDW12 is displaying
Hello there.
This is a well known fault with this particular dishwasher, error E4 and the audible alarm means you need to contact whoever you purchased the dishwasher from and ask them to repair it.
It needs serviced.
Hope this helps.
Posted on May 24, 2008
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Dishwasher - not washing
did you check the fuse
Jun 05, 2008 | Dishwashers
Powerpoint dishwasher IDW12 is displaying the error E4 with an error tone. The machine will not operate. How can this be fixed?
Hello there.
It needs serviced.
Hope this helps.
May 24, 2008 | Dishwashers
My dishwasher gives an E3 error
The E3 error code is not a defined error for this dishwasher. If you are sure it is E3 then best option is to give the controller a reset. This is done by
Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
Press OFF at this stage. Do not attempt to run the inspection as this could damage the dishwasher unless you are familiar with the what each mode does.
If the Error E3 keeps coming back then call the Samsung technician.
Apr 15, 2014 | Samsung DMR57LF Builtin Dishwasher
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
What is a E3 code on Samsung dishwasher
The E3 error code on Samsung dishwashers is due to the overflow water level being abnormally high inside the machine, this is caused by a blocked pressure system. Start by checking the supply hose for kinks and restrictions.
Jan 20, 2014 | Dishwashers
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
Apr 02, 2008 | Dishwashers
Dishwashers Logo
309 people viewed this question
Top Dishwashers Experts
Owen Barnes
