Question about Toshiba 57H81 57" Rear Projection Television
Focus error after i go threw the auto focus my color lines are off, i am watching like 2 pics just off of eachother a little 1 is blue and the other is red
  • Toshiba Master
  • 8,617 Answers
You need to replace both convergence ICs part number STK392-110 you can get replacements with free instalation instructions with pics at this link.
http://servicemanuals.vstore.ca/
Posted on May 07, 2008
Turned on tv and it looked like 3d. Found red horizontal convergence lines extremely bowed. Cannot correct with magic focus either in auto or manual. What is the fix and what is more cost effective ......
TAKE OFF THE FRONT PANEL AND FIND THE FOCAS ELECTRONIC FOCAS CONTROLS. USUALY BETWEEN THE LEFT SPEAKER AND THE FIRST CRT GUN. PAUSE A DVD WHEN THE CREDITS GOING. OR USE A MENU IN YOUR SAT RECEIVER TO LOOK AT. USEING THE GRID IN THE TV SOMTIMES IS NOT ACCURATE. YOU WILL SEE 6 SMALL KNOBS (RED,GREEN,BLUE)FOCUS AND(RED,GREEN,BLUE)SCREEN DRIVE .FOLLOW THESE STEPS 1 TURNDOWN RED AND BLUE SCREENDRIVE 2 FOCUS THE GREEN (YOU SHOULD SEE SCANLINES) 3 TURN DOWN THE GREEN SCREENDRIVE 4 TURN UP THE RED SD UNTILL YOU SEE RETRACE LINES THEN BACK IT OFF TILL THEY ARE GONE. 5 FOCUS RED (UNTILL YOU SEE SCANLINES) 6 TURN RED DOWN AND TURN UP BLUE 7 FOCUS BLUE (BLUE WILL NOT BE AS GOOD AS RED+GREEN NOW YOU ARE IN FOCUS, NOW YOU NEED TO GET SCREENDRIVE BACK THE BEST WAY IS TO, PAUSE A DVD ON A BLACK SCREEN SELECT PLAY MOVIE AND HIT PAUSE RIGHT AFTER . TURN ALL THE LIGHTS OFF IN THE ROOM AND USE A SMALL FLASHLIGHT TO ADJUST SCREENDRIVE SO YOU DONT MOVE FOCAS BY MISTAKE. THE TRICK IS TO END UP WITH A VERY FAINT GRAY SCREEN WITH EACH COLOR UP AS FAR AS YOU CAN WITHOUT SEEING ANY COLOR ON THE TV. WHEN YOU GET THIS TRY PLAYING THE MOVIE. MAKE SURE THE BRIGHTNESS AND CONTRAST IN THE TV ARE AT A NORMAL LEVEL BEFORE YOU START . COLOR,BRIGHTNESS,AND FOCUS IS NOW SET TO YOUR DVD PLAYER.DO A FINAL CONVERGANCE AND YOU ARE DONE!
IF YOU CAN'T GET A COLOR TO FOCUS YOU MAY HAVE TO DO THIS MANUALY. SOME TV'S YOU CAN LOOSEN THE NUT ON THE CRT LENS AND MANUALY FOCUS IT. (LIKE AN OLD CAMERA). IF YOU GET THIS FAR YOU MIGHT AS WELL CLEAN THE LENS WITH A VINEGER BASED GLASS CLEANER (SPRAY THE RAG NOT THE TV) TAKE A LOOK AT THE MIROR, CLEAN IF NEEDED. IF THE MIRROR IS REAL DIRTY THEN THE SCREEN MUST BE BAD TOO.TAKE THE SCREEN OFF AND CLEAN THE BACK SIDE IF NEEDED. LOOK INTO THE LENS AT THE PICTURE TUBE YOU SHOULD SEE A NICE BRIGHT CLEAN PICTURE IF IT LOOKS CLOUDY YOU NEED TO CHANGE THE LIQUID IN THE CRT GUNS.I DON,T THINK YOU WAN'T TO TRY THIS YOURSELF. TIP(I USE A LITTLE ARMOR ALL WHEN I CLEAN LENES, THIS REPELS DUST LIKE IN YOUR CAR) IF YOU CHANGE YOUR FLUID AND WANT TO KNOW WHERE TO GET NEW FLUID I PUT CLEAR ANTIFREEZE IN MY PIONEER TV 3YEARS AGO AND STILL LOOKS GREAT "NOT KIDING" HOPE ALL THIS YOU. IF YOU ARE NOT COMFORTABLE TO DO IT. HAVE IR SERVICE. REPAIRING THIS WILL BE YOUR BEST OPTION>THANKS
Jan 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
I just auto convergence my zenith tv and it fixed but still 3-D
Ur tv convergence ICS are dead.That why ur colors lines green,red,and blue are not linning up,and the colors look like 3-D pic.Must have soldering tools,and know soldering to fix convergence problems.Must replaced 2 STK convergence ICS and some or all of it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 29, 2010 | Zenith R56W36 56" Rear Projection...
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
AKAI PT5598HD - I HAVE REPLACED THE CONVERGENCE BOARD AND PICTURE AND SOUND ARE "ON" BUT "PERFECT FOCUS" WILL NOT BRING BLUE INTO FOCUS. "PF" STOPS AT 37% - RED AND GREEN PATTERS ARE SHARP BUT BLUE IS...
Most of these sets have a SCREEN/FOCUS block---usually all black with 6 controls----you need to look close at it as one row of 3 will be screen controls---don't touch those----the other 3 will be FOCUS- MARKED in little letters will be r,g,b(red,green blue). TWO ways to adjust the focus: 1. carefully locate the blue focus control and adjust to see if blue will improve in focus. 2. each of the 3 large lens where the picture comes out have a wing nut and a slot--you can loosen the nut and turn the lens---usually best focus that way is if the part that turns is in the middle of the available area to move it.
I should point out that all projection sets intentionally de focus the blue--the lines if blue should be clear but never as perfect as green or red--this is normal.
I do this here for free so if this has been helpful give me a vote here.
if you need direct help:
etower.766@netzero.net
Aug 20, 2009 | Akai PT5598HD 55" Rear Projection...
Blue color
On front bottom panel remove behind it will be your focus/screen block cobtrol adjust Blue screen drive and focus also how to enter service mode for convergence with set off PRESS and hold at same time ch-&vol- untill set comes back on release you should now be in service mode for convergence.
Feb 19, 2009 | RCA D52W19 52" Rear Projection Television
Pt5499hd akai
It looks like you may to replace the convergence units. It will require repair.
Jun 03, 2008 | Televison & Video
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
