Washing machine does not work
The machine fills up with water but the centre piece does not turn to wash cloths. on spin cycle the water goes out but nothing spins. yuo can here the motor but nothing moves
  • 240 Answers
Coupler or belt is out. whirlpool built machines use a coupler instead of belt. it is behind motor and pump
Posted on May 04, 2008
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
Me and my kids are going nuts because everytime we wash something, it goes off balance the clothes are wet and it flashes ue ''uneven'' even if it is only 1 piece of clothing . I have adjusted all the legs...
if the cycle does not gets complete then its --
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 25, 2009 | LG Washing Machines
Washer won't wash
Hi!
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | GE Washing Machines
Washert not draining
If your washer spins but doesn't pump the water out, the drain line might be clogged.  In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. You already have replaced the pump motor and still no operation,  so check the power voltage to the pump during the drain cycle.   Verify the problem is not pump related as much as power to the pump being the problem.
Mar 15, 2009 | Frigidaire FWS445RF
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine will not drain
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
Jun 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
