I have a thomson tv model Quadra and remote RCT3003K. now the problem is - -- by pressing the keys even hardly TV does not respond. how to solve the problem
Gigatech
  • 259 Answers
SOURCE: emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
SOURCE: TV appears to be recieving remote codes but not responding
i was wondering if anyone could give me the code for the sanyo tv i've tried everything that i can but i'm unable to get the codes
Posted on Dec 30, 2007
SOURCE: volume not responding on Direct TV remote
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD221RD.pdf
See Page 15.
Worked like a charm! Good luck!
Posted on Nov 28, 2008
SOURCE: HI, TV Thomson Black DIVA
how to known the service mode for thomson tv blackdiva
Posted on Dec 31, 2008
SOURCE: Need code for Thomson DTI61300 remote for Elonex TV
Use 0538
Posted on Mar 06, 2009
How to program my quadra surf remote to hitatchi television
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 15, 2012 | Thomson 14MG135 14" TV
Was is the code for thomson remote control
1. Switch on the set you want to control.
2. Hold down the S key until the key that corresponds
to the last mode you selected blinks 3 times and
then remains lit.
3. Press the key that corresponds to the type of
equipment you want to control:
TV: television set,
VCR/DVD: video recorder - DVD player.
4. Direct the remote control towards the set and try to
switch it off by pressing the key B.
5. If the set you want to control switches off, press OK
to memorise the subcode.
6. Should the set not switch off, press key B as many
times as required (up to 200 times), until the set
switches off. Between two key presses, leave
enough time for the key corresponding to the
selected mode enough time to light up again (about
1 second). Proceeding this way will enable you to
see whether the set responds or not.
7. Immediately upon the switching-off of the set to be
controlled, press OK to store the code.
Feb 10, 2011 | Thomson ROC2404 Remote Control
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
THOMSON - QUADRA 21''(21MT62IN)
were you able to get the problem solved Even I have the same problem
Sep 08, 2008 | Thomson 21DC320 21" TV
Thomson top up tv remote codes
need sequence to tune in remote controller
May 13, 2008 | Televison & Video
Jan 15, 2008 | LG DR-4810 DVD Recorder
Thomson tv, model quadra 21
reset the memory of your tv,or the EEPROM.to reset it just simply unplug the unit,then press together the menu and the vol+ buttons,then press the power switch,when its on,release together the from pressing menu and vol+
Oct 18, 2007 | Thomson 21DC320 21" TV
Gemini universal tv remote
I lost a few manuals myself. Gemini Universal Remote Control Programming Codes ------------------------------------------------ 1.Locate the 3-digit brand code from tables below. 2.Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator turns on (3-4 sec) 3.Select the type of device you are programming by pressing the TV, VCR, CTV or AUX key. 4.Enter the 3-digit brand code number. If a valid code was entered, the indicator light will go off. 5.Test your Gemini remote,by pressing PWR key. Repeat 2-5 with new code number if not responding. Autosearch Instructions: If your remote has an auto search on it. 1. Turn ON the device you wish to program the Gemini to operate. 2. Press and HOLD the RCL and ENT keys simultaneosly, until the red indicator light turns ON. 3. Select the type of device you are programming by pressing one of the TV, VCR, CTV or AUX mode keys. Now enter one of the following device type search codes: TV-990, VCR-992, Cable-994. 4. Aim the Gemini at the device and press the red PWR key. If your device turns OFF, press the appropriate device mode key again,(TV,VCR,CTV or AUX),to lock in brand code for that particular device and exit from the programming mode. 5. If the device doesn't respond, press the VOL"+" key once to advance to the next brand code. Now press the PWR key again. Remember to immediately lock in your code when the component turns OFF by pressing the proper mode key. Continue repeating steps 4&5 until your device turns OFF. I hope this helps you out, Good Luck to you. TV Codes ADMIRAL 400,530 MITSUBISHI 020,160,180,190,230,240,580 AKAI 160,240,550 MTC 140,180,300,310 AMARK 390,590 NATIONAL 010,270,420,510,570,610 AMSTRAD 110 NEC 180,190,240,300,310,580,620 ANAM 170 PANASONIC 010,270,420,510,570 ANAM NATIONAL 420 PHILCO 080,120,130,180,270,240,270 AOC 180,240,300 300,390,450,490,540,590 BELL&HOWELL 530 PHILIPS 080,120,130,180,270,300,450 CANDLE 060,080,300,310 490,540,560,590 CENTURION 190,580 PORTLAND 390,590 CITIZEN 060,080,140,300,310,390 PROTON 240,390 CONCERTO 310 QUASAR 010,420 CONTEC 170,260,470 RADIO SHACK 070,170,190,390,410 CORANDO 390 RCA 090,180,240,400,500,600 CORONADO 590 REALISTIC 070,150,170,190,390,410 CRAIG 170 SAMPO 190,300,580 CURTIS MATHES 030,140,190,300,390,470 SAMSUNG 140,180,190,300,310,390,410 590,650 580,590 CXC 170 SANYO 200,430,460 DAEWOO 180,340,380,390 SCOTT 020,190,390,580 DAYTRON 190,390,580 SEARS 020,140,190,200,210,390,430 ELECTROHOME 160,390 440,460,590 EMERSON 020,110,150,170,240,280 SHARP 000,050,070,390,590 330,390,470,590,650 SONY 350,550,640 ENVISION 300 SOUNDESIGN 080,240 FISHER 200,460 SSS 170,180 FUNAI 020,170 SYLVANIA 080,120,130,190,270,300,360 GE 010,040,290,400,420,630 450,490,580,630 GOLDSTAR 180,190,240,310,390,590 TATUNG 420 HITACHI 100,260,310,320,390,590 TECHWOOD 310 INFINITY 270 TEKNIKA 020,060,080,140,160,170,180 JBL 270 270,310,390,480,530 JVC 030,250,370 TELERENT 390,530 JC PENNEY 040,180,190,240,290,300 THOMSON 400 390,400,440,500,630 TMK 240,310 KLOSS 490 TOSHIBA 140,200,210,220,440 KMC 390,590 TOTEVISION 390 KTV 170,240,390,590 UNIVERSAL 040,290 LLOYTRON 390 VIDTECH 180 LODGENET 530 WARDS 020,040,070,120,130,180,190 LOGIK 530 240,270,290,300,390 LOGIX 530 YAMAHA 180 LUXMAN 310 YORX 190,580 LXI 000,190,210 ZENITH 520 MAGNAVOX 080,120,130,190,270,300 390,450,490,580,590,630 MAJESTIC 530 MARANTZ 160,240,300,450,490 MEMOREX 530 MGA 020,160,180,190,230,240,300,580 VCR Codes AKAI 002,052,112,202,372,402 MULTITECH 072 AMSTRAD 072 NATIONAL 272 ASA 022 NEC 202,252,292,302 AUDIO DYNAMICS 202,292 NORDMENDE 202 AWAI 392 PANASONIC 272 BROKSONIC 282 PENTAX 332 CANDLE 022 PHILCO 272 CANON 272 PHILIPS 272 CITIZEN 022 PIONEER 252 CRAIG 092,182 PORTLAND 232 CURTIS MATHES 272 QUASAR 272 DAEWOO 062,232,342 RADIO SHACK 022,072,092,142,152,182,272,312 DAYTRON 232 RCA 032,182,272,422,452,492 DBX 202,292 REALISTIC 022,072,092,142,152,182,272,312 DUAL 202 SABA 202 DYNATECH 072,142 SAISHO 242 ELECTROHOME 022 SALORA 212 EMERSON 042,072,082,102,112,132 SAMSUNG 172,182,342,412 192,242,282,472,482 SANSUI 202,252 FERGUSON 202 SANYO 092,312,382 FINLUX 072 SCHAUB 202 FISHER 092,322,332 SCOTT 132,212,242,342,432 FUNAI 072 SEARS 022,032,092,162,312,322,332 GE 182,272,422 SHARP 142,222 GOLDSTAR 022,292 SONY 122,252,352,362 GRAETZ 202 SYLVANIA 212,272,452 HARMON KARDON 292 SYMPHONIC 072 HITACHI 032,072,202 TASHICO 022 INSTANT REPLAY 272 TATUNG 202 ITT 202 TEAC 072,292 JCL 272 TEKNIKA 022,072,272,502 JENSEN 202 TELEFUNKEN 202 JVC 012,202,252 THOMSON 202 JC PENNEY 022,032,272,292,302 THORN 202 KENWOOD 202,252,312 TMK 042 LLOYD 072 TOSHIBA 162,202,212,342 MAGNAVOX 272,452 TOTEVISION 022,182 MARANTZ 272,292,452 UNITECH 182 MARTA 022 VECTOR RES. 212,292,302 MEI 272 VIDEO CONC. 302 MEMOREX 022,072,272 VIDEOSONIC 182 MGA 022,192,212 WARDS 022,072,142,182,222,272 MINOLTA 032 YAMAHA 202,292 MITSUBISHI 022,192,212,442 ZENITH 122,252,432 MTC 072,182 CTV (Cable TV) Converters Anvision 104 Realistic 504 Cablestar 104 Regal 444 Diamond 444 Regency 164 Drake 144,284 Rembrandt 474 Gemini 244,274,474,534 Samsung 094,374,474 General I. 004,034,044,204 Scientific Atlanta 074,524 GI/Jerrold 004,014,024,034,044,204,234,244,354 Sprucer 494 GI/Starcom 394 Standard Component 474 Hamlin 424,434,444 Starcom 014 Hitachi 414 Stargate 484 Kate Vision 474 Sylvania 114 Macom 184,304,324 Tocom 194 Magnavox 054,104,124,344 Toshiba 184,264 NSC 474 Tri-Vision 124,234,354,364,384 Oak 294 Unika 154 Panasonic 334,494 United Cable 014 Paragon 454 United Satellite 224 Philips 054,104,124,134,174,214,254 Videoway 314 Pioneer 064,084,094 Viewstar 054,104,124,134,174 Pulsar 484 Zenith 144,184,404,464,514 Randtek 104
Jul 01, 2007 | Gemini 1 Device Universal Television...
Kameleon Radioshack 8in1 need soundfiles
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Sep 24, 2006 | Radio Shack Kameleon 8-in-1 Universal...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
