Question about Amerock 3 Ring Knobs - BP1586
The door knob rotates but the latch does not retract. I removed the screws, the handle is hanging but I still cannot unclick the latch. The nob is a single handle brushed chrome about 5 yrs old with a lock knob in the center. It occured today. Never had a problem before.
3 Suggested Answers
jeltey
  • 44 Answers
SOURCE: Can't close back door without turning the knob
Try taking the knob out of the door and spraying the whole latching mechanism with WD40 or some kind of lubricant. There is a few moving parts in there that can get bound up. Hope this helps. Don't forget to leave feed back.
Posted on Dec 03, 2008
  • 187 Answers
SOURCE: Broken door knob, cannot enter room
I know I don't need to mention that knobs with an emergency release inside the house are wonderful things. Many function by sliding a nail into a hole in the middle of the door knob, others use the push/turn technique.
First thing to try is pushing the door knob in and then pulling it out while turning it as far as you can in both directions. If a part is worn out or misaligned, sometimes this is just enough to do the trick. If that doesn't work:
Now that the pins are out of the hinges, try working with another person if you can. Don't concentrate all of your efforts on the latch if you haven't been able to access it because of the moldings. Hinges get sticky and may need a good nudge.
Have one person push the door up from the bottom or top with a small pry bar or large screw driver. While this is happening, watch the hinges. They fit together like a jig saw puzzle, there should be play and they will loosen up a bit now. Now you will have an idea of the best way to try this.
Remember, the hinge side is no longer attached, so caution is in order. If you are working from a side without molding, pull out from the bottom and/or top while lifting gently with the pry bar. You can sometimes use a fulcrum and step on the pry bar if you are alone.
If molding is blocking your side, try pushing the hinge side inward. If that doesn't work, Using the pry bar, go to the bottom corner on the door knob side and tilt the door toward the opposite corner as much as possible.
If you can, jam something as sturdy as possible (screwdrivers)above and below where the latch is. With another screwdriver of tool, push directly into the latch and push the handle of what you are using in the direction opposite the door. Give it a good yank.
Try to be observant and creative while doing this. You are looking to try and squeeze out just a little more space. Use any area where you see play. Underneath, along side, up top, where ever.
There will undoubted be some damage to the wood or paint, remove the molding piece alongside the latch. It will be affordable to replace if you are a diy person.
For the others that commented, parts inside get worn and as mentioned above, the shaft has to be aligned correctly. If not, you run into problems like the latch not fully engaging.
Cutting the knob off will be a bit difficult. Even when that is done, it may be difficult to remove the latch and metal burrs are razor sharp. I think I would call a handyman before attempting that. Good luck all.
Posted on Nov 22, 2009
How do I remove the doorknob to possibly oil it?
it would depend on the door knob construction and what was stiff inside it.
The problem could be part of the handle or part of the lock mechanism.
For a typical indoor door lever handle, undo the screws on the face plate and take the handle off and oil as appropriate. You may have oil handles on both sides of the door.
For a rotating door knob handle there is generally a single screw on the underside of the knob
For a lock mechanism, you could just spray oil inside the mortise moving part (you wouldn't have to dismantle anything to do this!).
However to dismantle it, you'll need to remove handles on both sides of the door, remove the square bar that slots between both handles and remove the lock mechanism (you may have to remove locating screws that exist on the mortise face. If lock mechanism is user serviceable then there will be screws to undo to allow it to be dismantled. If none exist then it is probably worth buying a new one.
Oct 16, 2014 | Hardware & Accessories
I have a motorhome with a trimark handle model
The latch to be removed by taking off the inside plate. there should be a couple phillips screws on the inside. the handle should come off with the plate exposing the latch so it can be turned with a screw driver to open the door and replace the latch.
Sep 10, 2014 | RVs
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Door dosnt latch closed
My name is mike, thanks for directing your question to me. First of all Your latch needs to be replaced. If it is not working proper it also triggers that machine door is not closed so of course it wont start. Here is a site link that might help you some as well.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
If this helped you, please rate my free help and some nice words would be nice. Thanks Mike.
Also here is my personal Market Place site for other areas of my expertize.
http://beta.fixya.com/users/mc1beanThanks Mike
Oct 31, 2011 | Washing Machines
Removing/installing 2000 dodge grand caravan window glass
after u remove the bolts that hold it to the window regulator tip the window towards the front of the door and the top rear corner of the window should pop out and then u just lift hte window out,hope this helps
Sep 05, 2009 | 2004 Dodge Caravan
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Nov 26, 2008 | Top Knobs Hardware & Accessories
Nov 22, 2008 | Amerock 3 Ring Knobs - BP1586
Amerock 3 Ring Knobs - BP1586 Logo
1,947 people viewed this question
Top Amerock Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Amerock Hardware and Accessory Expert? Answer questions, earn points and help others
