Question about Technics SUV500 2-Channel Amplifier
Red light went off and only the amber light stayed on, no red current light on it looks like i might be a power supply problem ? can you please help thanks as iv had this amp for some time and don't really wanna bin it, if u can tell me what can do if it is the power supply where can i buy 1 from thanks again kyri
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 99 Answers
It's most likely the main power amp IC which is screwed to the heatsink.
The current drive LED always goes out when this fails.
Posted on Jul 16, 2012
Dell Power Edge 2900 - amber and Red A light on tape Drive
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. May also be a defective card inserted into your motherboard. Try isolating the problem by removing all components until you just have motherboard and power supply and see if it turns on.
Feb 13, 2014 | Dell Computers & Internet
We turned our tv off for like 3 hours went to turn back on and red light turned blue like it was going turn on but screen stayed black then speaker made a noise and light went back to red. It did that 28...
The problem is the power supply of your television.The power supply have abnormal voltage supply output cause of leaked capacitor.The leak capacitor have bulging tops, so that you can identify the leak capacitor. Just remove the cover and find the power supply and replace new capacitor with same polarity.Hope it will help you.Thanks..
Sep 04, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Xbox 360 won't turn on and the kids are upset.
Press the power button on the front of the Xbox to turn it on.
As you're doing this look at the power supply to see if the amber light turns green.
If the light does not turn green, you'll need to get a new power supply.
I you think this information is helpful to you, please take a few minutes to rate this reply.
Aug 29, 2009 | Microsoft Xbox 360 Console
Thomson topupbox
hi i have sorted the problem i went on line of the make of the thomson freeview and their was other people with the same problem and they help me by reading their instrutions on their page now it is working .
May 04, 2009 | Thomson DTH8000 DVD Recorder
Power supply problem
The blinking amber on a Dell usually means 1 of 2 things. Either it is a video card which has either come unseated, or went bad [most likely in your described case] or bad or unseated RAM. If reseating your video card does not fix problem then it will need to be replaced. Hope this helps & please rate my solution fixya. Thanks.
Feb 04, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Flashing Power Pack
Amber light is ok its when its red that is the problem, this might be your 360 that is faulty and until we have a closer look we would not be able to help further. You could try a different power supply from a mate, if the console works with a different power supply then you know its your supply thats faulty. but if the 360 still will not turn on then its the 360 at fault. Be carefull when using different power supplies as there are currently i think 4 different revisions and all have different power ratings. We could look at this for you www.fixmyconsole.co.uk
Jan 24, 2009 | Microsoft Xbox 360 Console
PROTRON 26 TWO YEARS OLD
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Windows XP won't start
The amber light is the error light on a Dell. It can mean a few things. 1. RAM has went bad, not properly seated. 2. Video card has went bad or come unseated. 3. Power supply is not working properly; or 4. Motherboard has went bad. Hope this helps & please remember to rate my answer.
Jan 02, 2009 | Dell Dimension 2350 PC Desktop
IS-LCDTV32 32 will not stay powered on
Went dead? no power light? if you had no lights at all its probably the power supply, if you had a red light then I would go with the main board. Disconnect the lcd panel from the main pcb and inverter and see if your blue light stays on. If so you have a bad panel.
Aug 21, 2008 | Insignia IS-LCDTV32 32 in. Television
Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Jul 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Technics SUV500 2-Channel Amplifier Logo
144 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
