Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark X 4270
My lexmark will fax and scann but I can not receive incoming or out going faxes. The dailing tone is working fine -it dails the number but fails to connect. What is wrong?
  • Anonymous May 06, 2008
    i am unable to recieve faxes.it rings and say connect i press start then it says failed to connnect what do i do please help thank you
    Genius:
  • 2,035 Answers
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
I can not send a fax with samsung scx-4521f
do a simple test. press the onhook button to you hear dail tone. try key in your mobile number and see if you got the call.
if all the above is yes there is no issue with the modem.
if you did not hear any dail tone. check your phone line is it working fine.
make sure that your phone line is not hunting line. fax machine does not work with hunting line. only direct line.
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
No dial tone.
Take the line out of the fax and put it in a telephone,if u hear a dail tone its the fax and if not its the phone line!I am allmost sure there are fuses on the fax board that can be bridged!Good Luck!
Apr 07, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
How do I fax multiple numbers at once?
You have to setup a group Dial.First setup yur one touch dail numbers under user mode-Tel registration,one touch speed dails.Leave at least 1 dail open and program it to a group dail number.Under usermode-tel registration select group dail and select your group from the one touch buttons.
Dec 14, 2009 | Canon LaserClass 720i Plain Paper Fax
I can recv. faxes, but every time i try to fax, I get a dail tone then after dailing the fax number,I am told the number has been disconnected
more than likely, the destination number has been disconnected or changed. this is not an error from your device but from the teleco
Aug 06, 2009 | Dell 2135cn All-In-One Laser Printer
Lexmark X6170 Has a shared phone/fax line with different numbers
Open the Lexmark "Fax Printer Setup Utility". Click on the "Connection/Dialing" tab. In the "Interact with Phone Line" section, "Answer Incoming Calls:" should be set to "If fax tones are detected".
If this is turning out to be too unreliable for you, you will need to either manually receive incoming faxes (by changing the setting to "Manual"), or you will need to at least spring for a separate phone number with a distinctive ring for incoming faxes.
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
I have just puchased a new Fax machine, I only have one telephone line but when I sent the machine to Fax/Tel the machine takes over and keeps ringing until i press tele/Rev..I want to receive incoming...
I always setup my faxes with FAXONLY mode,I set the incomming ring to "on "and ring count to "7".
And check wat is your remote rx number-with that number you can dail it and it will go to fax automaticly.
Nov 04, 2008 | Brother Office Equipment & Supplies
Problem connectine fax line to...
First of all what type of phone line r u using ....is it a normal phone leine or DSL....
IF u have a DSL...u need to have a splitter...
If u have normal phone line then connect it directly to printer in the line jack...and from Ext jack to phone...
Check if get on hook dail...ie..see if u can hear the dial tone...
Try sending a fax and if u get a msg "fax Complete " then its working
Jun 20, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax
i need simple instructions to operate the receiving and sending of fax information on this lexmark 4270 fax machine .
Jan 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
