Question about 3Com OfficeConnect Wireless Router
3com 3crwdr200a reboots every 30 minutes
Upgraded to official firmware v3.0.1. It reboots every 30 minutes when connected to internet. please help. any advise other than using un-official firmware?
  • 1 more comment
  • dunded May 05, 2008
    1) not reboot literally. the best word to describe it is freezes/hangs. i retest it again and the same happen even when it's not connected to internet.
    2) my friend has a 3crwdr101a(earlier model, 54mbps) and it works fine
    3) don't think it's my isp.
    4) i don't have modem. this is an adsl router
    i'm thinking it's the faulty router. should i send it for RMA(repair)?
  • iori172 Sep 11, 2008
    i have the same problem whith same router; my router freez many times per day when i'm connected to internet, and i don't know what to do,please help me :(
  • Anonymous Mar 11, 2009
    Same issue here. Router hangs/stops at random. Longest it's been up is two hours. I think it's overheating. I don't know all I can tell is that after a hang it's hard to hold on to for more than a few seconds. Too hot!
  • 42 Answers
The 3com website is remarkably shoddy on this issue, and doesn't have the newest required updates. Even the KB on their site is thin on solutions.
You really need firmware 3.6.4, yet 3.0.1 is the latest on the official website. Try this page:
for the very latest firmwares, and note that it's best to clear out the router memory completely before adding the new firmware to it. This is because it sometimes doesn't like the new image files otherwise. The way I suggest:
1. Note all of your settings manually (don't save a config file, it may not read back in).
2. Hard reset and clear the memory, by holding down the reset button and powering on.
3. Connect to with your browser - you may need to mess with the network settings on your PC to get it to connect. You will see a very bland screen, asking you for a firmware file, rather than the traditional login screen.
4. Upload the latest firmware, downloaded from the site above.
5. Allow the router to do it's business and restart.
6. Connect back to, and you will once again see the correct router software, with a new install wizard.
7. Re-enter all your settings, as noted above.
Posted on Mar 11, 2009
  • 77 Answers
Hi there!
If I were you, DO NOT use a firmware that you didn't download at 3com's site since it will void the warranty (based on experience with other manufacturer).
You're using the lates firmware of 3.0.1 (I checked it at their website).
I have some questions for you:
1. Does it reboot literally? I mean, the router turns off then on after 30 minutes?
3. Who's your internet provider?
4. DO you have a modem? If Yes, what's the brand and model?
2. Have you tried isolating the problem by trying a different router?
Posted on May 04, 2008
Configuring a 3COM 3CRWDR200A-75 router as a repeater
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to then the repeater router should use a higher number (ie. 10), such as or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Nov 17, 2012 | 3Com OfficeConnect® (3CRWDR200A-75) Router...
3COM 3CRWDR200A-75 Firmware Download - All Versions
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
I'm upgrading firmware of the 3com 7760. I'm get from and i download a file .img, but in the 3com web interface say "Please Input Address Path for Upload". I selected the file .img. Excuse me...
i know this was from a while ago but 3com 7760's have a problem when uploading it files either firmwere or setting backup files you have to use internet explorer or you will get the "please input address path" error
Aug 04, 2010 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Every time my laptop powers down and reboots i connot connect to the internet unless i power cycle both router and modem? any idea ?
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Click here for step by step instructions.
Jul 20, 2010 | Linksys WRT54G2 Wireless Router
Ugrade 3com router 3CRWDR200A-75
The first thing I would check would be in the configuration (point your web browser to when you have a wired connection) panel, under:
Wireless settings > configuration
If the 'Wireless mode' is set to 'SuperG', this may be your problem. The SuperG setting will only work with SuperG enabled wireless adapters. First change this setting to 'Mixed 11b/11g'; if it still doesn't work switch down to '11g' then to '11b'.
Do all your wireless testing with a laptop or PC as close to the router as possible - same room at the very least.
If all other settings are correct (double check them), this is the only thing I can think of that can instantly make a difference.
If you feel the firmware may be faiilty, note that although 3.0.1 is the 'newest' on the 3com website, even in their own knowledge base they refer to newer versions. These newer versions are available at:
You could try using one of these (at your own risk), if you feel it is the firmware itself that is causing the fault.
Mar 24, 2009 | 3Com OfficeConnect Wireless Router
How to put wep password for 3com 3CRWDR200A-75...
all the documentation is here and the installation software if you need it is at the bottom of the page
Sep 06, 2008 | 3Com OfficeConnect Wireless Router
Router stops responding with red alert light turned on
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Dec 27, 2007 | 2wire 2700HG-B Router (2700HGB)
I had the same problem since a bought it last week and I was going crazy. Install this firmware and everything will work fine:
Oct 20, 2007 | 3Com OfficeConnect Wireless Router
3com wireless
Problem like this is a manifestation of a corrupted firmware. Try to upgrade the routre's firmware.
Oct 08, 2007 | 3Com OfficeConnect Wireless 108Mbps 11g...
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
3Com OfficeConnect Wireless Router Logo
556 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
