Question about Kenmore 24032\24036 Top Load Washer
How to take out agitator on kenmore 800 washer
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
5 Suggested Answers
  • 92 Answers
SOURCE: WASHER WILL NOT AGITATE OR SPIN WILL FILL AND
sounds like your motor coupler bad if its making a ratchety kind of noise
Posted on Jan 15, 2010
  • 56 Answers
SOURCE: washer fills agitates and drains but wont spin
sounds like you need a drive coupling. tip the machine back and remove the motor and pump. the coupling is between the motor and gearcase.
Posted on Feb 08, 2010
dr appliance
  • 266 Answers
SOURCE: Kenmore 800 series washer is off a cycle. The
bad pressure switch or plugged pressure switch hose.....
Posted on Jan 31, 2011
SOURCE: my kenmore 800 washer is off cycle for example
http://www.appliance-repair-it.com/washer-agitates-while-filling-whirlpool.html
Read the numerous threads, most are pertaining to Whirlpool, but it is the same issue/resolution. Hope this helps!
Posted on Oct 21, 2011
Kenmore 800 washer agitates before filling with water
This could be caused by a couple of problems. The water level sensor could be bad so that the washer thinks it's got water in it already or the timer could be bad. If the washer starts to fill after it starts agitating then the timer would be the problem.
May 30, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore 800.agitates and fills the same time
no usually the water stops coming in before agitation starts. check the water level sensor it might be plugged with soap crud
Oct 28, 2017 | Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Washer fills agitates and drains but wont spin kenmore 800 series
Feb 07, 2010 | Kenmore 24032\24036 Top Load Washer
WASHER WILL NOT AGITATE OR SPIN WILL FILL AND DRAIN KENMORE 800 TOP LOADER APROX 13 YRS OLD
Jan 15, 2010 | Kenmore 23822 Top Load Washer
Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,412 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
