Question about Frigidaire FEF336BC Electric Kitchen Range
Self clean oven door lock will not unlock - Frigidaire FEF336BC Electric Kitchen Range
  • 4 more comments
  • Anonymous Jun 21, 2008
    self clean cycle ended 6 hours ago and doors are still locked
  • mwert Jul 18, 2008
    I did the cleaning cycle and the oven door locked as usual; but when cleaning cycle was completed; the door remained locked and the Lock lite is still blinking.
    Please help.
    mwert@jackhenry.com
    Thanks!
  • Anonymous Aug 14, 2008
    I accidently leaned on the oven door gizmo, and the word and icon for Lock appeared. How do I unlock this oven door. I was not trying to set oven for cleaning, just touched the keypad by accident.
    Thanks,
    • Really concerned that I can't unlock it, no matter what combinations of keypad choices I've tried.
  • menakashok Aug 26, 2008
    When I press the auto self clean button, Oven gets automatically locked. I couldnt open the oven even after it completes the clean. after 2 hours I tried open the door. Still its locked.... can anyone give me tips to unlock Oven.
  • pit495 Sep 09, 2008
    My GE oven door also wont unlock after going through selfclean operation
  • chrieistine Feb 19, 2009
    push self clean, locks and beeps f9
Hello!
My new name is MopperLocker...
I created the same issue when I was mopping my kitchen floor and I somehow, accidentally, flung my elbow against the door, rendering it locked... I was quite chagrinned, and informed my beloved (and heroic) husband, Bill, of the fact.
But I digress... Mostly because my BAHHB had absolutely nothing to do with fixing the problem...
Here are two methods of fixing it:
1) Purchase a new oven - one without a lock.
Or...
2) Unlock the door - Here's how:
a) Grabbing the handle, push the door in (like you are trying to force the thing all the way to the garage through the wall).
b) While doing this, hold down the clear/off button until the "door lock" light starts to blink like you are choking off the electricity that keeps it lit.
c) (This is the tricky part) Repeat step 2 - I mean "b" - until you really have killed the light, and the appliance gives off an audible clicking sound, signifying that it has been rendered open-able again.
Now you can open the door and pull out the ham you were baking before it begins to rot. And smell bad.
Posted on Sep 20, 2008
Oh my god THANK YOU. ,Somehow I had already fixed this once by accident have no idea how it happened either time. LOL. BUT I do know that I was in a panic ready to go buy a greaser whatever to boil the turkey.
Anyway .. I had my son shut down my computer and he had just finished that when I came back to THANK YOU.
THANK YOU.
Happy Thanksgiving.
Posted on Nov 26, 2008
3 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: Self clean oven door lock
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Posted on Sep 09, 2008
SOURCE: oven door will not unlock after self cleaning
I had the same problem, and after about a month of troubleshooting, I finally found the problem. There is an overtemperature switch built into the electrical panel of the oven. Resetting this switch solved my problem.
To reset it:
TURN OFF THE POWER!
Open the door (if it is locked, turn the power back on and gently pull on the door every few seconds as the locking mechanism cycles until it is unlocked)
remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven)
pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, Look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure. Mine was located nearly in the middle of the electrical enclosure.
Push the tiny button on top of the switch. You should fee a click.
Reassemble and power up.
Posted on Oct 09, 2008
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
Nov 08, 2014 | General Electric GE 24" Single...
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
After self-clean cycle oven door won't unlock
your lach might have given out on self clean. change it
Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
Oven door remains locked after using the oven cleaning feature
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire FEF336BC Electric Kitchen Range Logo
831 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
