Question about Kenmore 74602 Gas Dryer
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
  • Kenmore Master
  • 1,564 Answers
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Posted on Sep 12, 2012
    Problem Solver:
  • 19 Answers
Check the dryer vent hose for lint or other blockage. If the dryer can't vent properly then the air doesn't pass over the clothing as it should and therefore it won't dry properly even though it heats up. Good luck.
Posted on Aug 23, 2010
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My Kenmore 400 series dryer has stop blowing hot air to dry my clothes. It blows room temperature air therefore, my clothes don't dry in a timely manner. How do I fix this problem? Thanks,
Hi Most ahve the same problem, maybe the dryer vent is plugged up , pull unit out and unplug it , remove vent and clean , then with a tester check over heat sensors at rear of dryer , they knid of look like diodes with two wires going to them , you could also by pass them with a jumper wire , BUT JUST TO TEST THEM ONLY ! it could also be th eelement , but most times it is a sensor form over heating unit , both are very cheep to fix,
Jul 27, 2011 | Kenmore 400 6942 Dryer
It takes 50 min to dry a load of clothes in my 400 series electric dryer can you tell me the problem. I checked the exhaust it looks clear thanks.
It could be heating problem and best way is to check for continuity in heating element and sensors and thermostats and limiters and thermistors in the dryer
Nov 17, 2010 | Kenmore 400 6943 Dryer
My Kenmore 400 series is taking too long to dry
Make sure the vent and tube are clear and not blocked in any way, if clear try washing off the lint screen with hot water, softener will clog the filter
and not allow proper air flow, water will bead up on screen if this is true
Oct 27, 2009 | Kenmore Dryers
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 74602 Gas Dryer Logo
314 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
