Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Our dryer started squealing 2 weeks ago and I was able to isolate the problem coming from the tensioner pulley. I can get this part from a local appliance parts store but I was needing some advise on how to replace it. I was able to lubricate it going from the front of the dryer. Should I go in from the back of the dryer to replace it? What is the best way to do this? I would appreciate your help in replacing this part. Thanks!
  • Russell Aug 23, 2010
    The model No. is WED8410SW0. I believe that the pulley is the problem because when I lubricated it, the squealing stopped. I had talked to the people at the appliance supply store who recommended that I try some WD40 on the pulley and the rollers individually to see which will stop the squealing and I started with the pulley which stopped it. It started to squeal again after 9 days of use and I lubricated it again which again quieted it down. So, I figured that it must be the pulley. So, I went ahead and bought the pulley and was going to replace it. I was asking how to go about doing it. The belt appears to be okay. Thanks for your help!
    Top Expert:
  • Whirlpool Master
  • 78,919 Answers
What is the model number? what is it you are replacing u never say. this is likely a belt problem not a tesioner pulley issue, they seldom fail.
Posted on Aug 23, 2010
  • 1 more comment
  • yadayada
    yadayada Aug 23, 2010
    please go to the web link below and scroll down and read about this very cheap poorly designed pulley and how to permanetly fix the problem.
    http://fixitnow.com/wp/2009/05/08/crappy...
    I was able to replace the pulley, fortunately it had the older pulley system not the glider and fix the dryer before your response came. It would have been nice if I had it before tearing it apart on my own! Thanks anyway!
  • yadayada
    I need to explain something about fixya, no expert on Fixya is a employee of fixya, we are technician's who do this in our spare time to help out and save u $'s, the amount of money we get for this problem for instance is $2.00 (US), so the effort won't make us rich, but the point is we have other things going on, we don't set at the computer, we check back from time to time, sorry for the delay but that is the way the system works, I tried to help.
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
MY WHIRLPOOL IED4400SQ0 DRYER IS SQUEALING?
Could either be the drum rollers or the idler pulley have to remove the drum the idler pulley is the one that maintains tension on the drum belt
Aug 30, 2014 | Whirlpool Dryers
Squealing noise
Sounds like one of your pulleys is bad. Alternator, water pump, don't know till you find it. You say you have more than one belt-try taking one off at a time, run engine for a couple of minutes and see if squealing goes away. Maybe you can isolate it that way.
If belts are off, you could spin each pulley by hand to see if you could catch the one that is bad. Any little wobble or play in any of the pulleys would be very suspect as the likely bad one.
May 11, 2017 | 1991 Plymouth Sundance
Chevy SIlverado Serpentine Belt Problems
Wrong routing of belt on your pulley, refer to your repair manual.
Dec 08, 2011 | Cars & Trucks
The dryer squeals on start up and quiets after 40 seconds or so. I took it apart and the belt and pulley seem ok. How do I know if they are worn? I thought it was a problem with the felt liner at either...
Sorry to read about your problem, I hope this helps you out.
you have a drum bearing, going bad, or your belt tension pully. it stops squealing because the unit heats up and the metal expands. you can also try spraying (WD40) the belt tension pulley..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Maytag MDG9606 Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Dryer squeals closer to end of cycles
Hello.
It will either be a drum roller or the belt tension pulley. Most dryers sell there parts seperately but Whirlpool sells a kit that has the rollers, pulley and the belt with a decent instruction sheet on how to do it. If you go to www.sears.com and click parts direct, there will be a place to enter your model number and get ahold of the parts you need.
Jul 22, 2009 | Dryers
High pitch squeal
sounds like the tensioner for the belts is worn
Apr 08, 2009 | 1996 Geo Tracker 2 Door
Major electrical problems, and then some...
If its still squealing after you have replace the belt, it is likely that one of the idler or tensioner pulley bearings have went out. You can pull the belt off and then try and wiggle the idler and tensioner pulleys and if any of them have wobble in them then that is the one that needs to be replaced.
Dec 31, 2008 | 1999 Saturn SL
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
66 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
