Question about Sport & Outdoor - Others
I have a model 812 minn-kota trolling motor I bought at a auction what is the voltage 12 or 24 volt
  • 3 Answers
12 volt
Posted on Oct 17, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Lookinf for a manual for a minn kota model 55d
    call 800 number for minn kota on your motor. they are very helpful and will fax or emial you a manual for the motor. good luck.
    May 28, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
    Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
    Nov 18, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    I just bought a 74 lb Minn Kota trolling motor that is 24 volt. It is used and has 4 wires (2 black & 2 red) coming from rolling motor. Can you please tell me how the wiring is connected to the...
    I have uploaded a image of the wire system. folllow it carefully. the fuses rating should be no more than than thirty amp. go to your local outboard dealer they sell inline breakers that are designed for trolling motors. i prefer them because you don't have to replace them after a overload. you just reset the breaker.de79e02.jpg
    Oct 29, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
    Year made MKAD2674059 minn kota
    According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
    *Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
    MKAC .......... 2002
    MKAD .......... 2003
    MKAE .......... 2004
    MKAF .......... 2005 MKAG .......... 2006
    MKAH .......... 2007
    MKAI ............ 2008
    MKAJ ........... 2009
    MKBA .......... 2010 A serial number with the designation MKAB denotes a
    2001-motor and MKBA would be a 2010-year model
    Jun 13, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    How does the minn kota 65 all terrain run on 24
    You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
    Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Sport & Outdoor - Others Logo
    178 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
