Question about Karcher Garden
I have a Karcher 330 elec. power washer. The on/off switch will turn the washer on but will not keep it runing
5 Suggested Answers
  • 1019 Answers
SOURCE: pressure washer karcher
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Posted on Mar 26, 2008
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 384 Answers
SOURCE: re - karcher 330
Overload contition in circuit. Turn some stuff OFF.
Posted on Jul 21, 2009
  • 68 Answers
SOURCE: I have a karcher power washer electric.
This could well be just needing a new motor capacitor as this helps the motor to start.
Posted on Jun 24, 2010
Karcher k3-91m electrical box
There is a strong possibility of a defective switch.
Aug 12, 2016 | Karcher Garden
Karcher k3.86 on/off switch does not work
If you are certain it is the switch, try looking on Ebay for a replacement switch.
Apr 16, 2014 | Karcher 1750 Psi Elec Pressure Washer
My Karcher 330 M has blown two water inlet ( Garden hose inlet ) elbows. Replaced one and then after about 5 min operation shut off the valve on the wand and immediately the new elbow split the same as the...
I have a larger gas powered karcher, just make sure the water going to your karcher is not obstructed from its path. on mine i bought a goodyear hose that can be purchased at northern tools or any hardware store. and use it just for pressure washing. good luck!
Dec 23, 2010 | Karcher PSI Electric Pressure Washer
My Karcher K9.8 electric pressure washer started
Not Simple.
I have the same Problem, the leak is from the seam of the Manifold or on the pressure side of the Pump and the hose housing. In my case there is a small crack in the seam of the Manifold Housing. A manufacturing defect.. A New Manifold Complete Replacement about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
May 18, 2010 | Karcher 1750 Psi Elec Pressure Washer
I have electric Karcher 330. i did not use for a couple years. tried out today from storage, it seemed the water jet was not strong, so may be the pumper problem or I need to clean the inlet hose? thanks!
the problem is your water seals,
you need to change them,
over time it became dry rot.
have the pump service at the same point.
the springs in the valves can be rusty and brittle..
Nov 21, 2009 | Karcher K2.26 Electric Power Washer
The motor keeps surging
If there's a lot of sediment in your water supply, there's a chance that sediment has gummed up the pressure switches. I'm assuming it has a full power switch and high power switch. It runs on full power until a pressure switch is satisfied, and runs on low power to slowly build the pressure back up, at which a second switch is satisfied from the pressure and turns the motor off. These things are not easy to work on, and are made of metal probably too fragile to try any chemicals. You should probably contact the manufacturer.
Sep 19, 2009 | Karcher 1750 psi Electric Pressure Washer
Trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
Aug 03, 2009 | Karcher K2.26 Electric Power Washer
Re - karcher 330
Jul 21, 2009 | Karcher K2.26 Electric Power Washer
Karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Jul 05, 2009 | Karcher K2.26 Electric Power Washer
My karcher pressure washer has lost its water power
I hope this helps.
Apr 25, 2009 | Karcher Garden
Garden Logo
396 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
