Question about Electrolux EWDW6505 Builtin Dishwasher
Electrolux Dishwasher Model # EWDW6505GW0 is inoperative and Error code # 01 is displayed. What does this mean?
COXY
  • 76 Answers
SOURCE: Electrolux Gallery Dishwasher Error Message AL3
It sounds like it could be a heater problem, I would check this first
Posted on Nov 27, 2007
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Posted on Dec 28, 2008
SOURCE: electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Posted on Jan 12, 2010
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
  • 3 Answers
SOURCE: lg dishwasher ld2120w is displaying
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. I resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first. I think the origin of the problem might be too much food on the plates and too strong of a dishwasher gel detergent so the food is turned into gunk which coats the channels of the plastic assemblies.
Add a comment
Posted on Nov 07, 2010
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
What does 01 error mean?
Hello Ned, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "01". This error code means that a leak has been detected. Have you noticed any water coming from the bottom or near the dishwasher? This could also be a miscommunication within the control of the dishwasher and a reset may help clear that out. You can reset your dishwasher by disconnecting power from it for at least ten minutes. If that does not help to resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to some degree. -Matt
Jan 22, 2016 | Electrolux Dishwashers
Error code CO HOW DO I CLEAR IT ON THE DISHWASHER
Hey Robert, thank you for your post!
Based off the information you have provided your Electrolux dishwasher is displaying an error code of "CO" and you would like to clear it out. The error code "CO" means that there is a miscommunication within your dishwasher. The best way to clear the code out is to perform a reset and you can do that by disconnecting the power cord for at least ten minutes. If the code continues to display this could mean that your keypad, a wiring harness, or control panel may need to be replaced and I would recommend having a professional technician out. They would have the appropriate tools needed to disassemble your dishwasher and test each component. This will help protect you from any unnecessary part purchases. -Matt
Jan 15, 2016 | Electrolux Dishwashers
Model EIDW6305GSI error code 03 comes on after about an hour after cycle starts could anybody tell me why this happens thanks
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
Have an error code 01 on my electrolux dishwasher
Good Morning Friend, I am happy to assist you!
Typically error code ER01 indicates that a water leak has been detected under the tub of your Electrolux dishwasher. Your dishwasher may possibly need a hydraulic kit. Try unplugging your dishwasher or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and turn on your appliance. If the error code continues to display, then I recommend contacting a professional to make a precise diagnosis. Best regards! - Z
Jul 20, 2014 | Electrolux Dishwashers
Error code 01 after problem has been fixed on electrolux dishwasher
I understand you are receiving an error code "01" on your Electrolux dishwasher, even after the problem was fixed. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Dishwashers
More than one error code 01 on electrolux dishwasher
I understand you are receiving more than one, error code "01" on your Electrolux dishwasher. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why you are still receiving an error "01" on your dishwasher. Hope this is helpful.
-Best Regards-
WP
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
EWDW6505GS0 Model Electrolux dishwasher 10 months in service has Error Code 01. Leak. What to do?
Feb 14, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Electrolux EWDW6505 Builtin Dishwasher Logo
103 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
