Question about Gateway 7510GX Notebook
I need to replace the lid switch in my gateway 7510 GX or else simply disable it. I removed the button that gets pressed but seems the circuit is already messed up, and I need to mess with it every time I do a cold boot. I cant find a replacement part anywhere, so want to disable it but I am wondering how the thing is supposed to work , since the thing seems to not be all or nothing. Simply removing the whole switch from its connection to the MB or breaking cutting a wire does not result in always on status, I always need to fiddle with it and get a plate to move a little to restore power to the backlight. I dont really mind if screen becomes an always on thing, I never close the lid anyway really except when its in hibernation, but for the life of me I cant get the computer to ignore this switch at all.
  • 4,737 Answers
Try this, go to Control Panel, open "Power Options" and on the left pane, click "when I close the lid...." or similar options for Lid and and choose "Do nothing" on both the options available on "Close Lid" menu. Save the settings and try whether this helps or not.
(you can go to the power options by right-clicking the desktop, select "Properties" then to "Screen Save" [XP] or to "Power" tab.)
Good luck.
Thanks for using FixYa.
Posted on Aug 23, 2010
  • eagle_203 Aug 23, 2010
    This setting is set to do nothing. to be clear my exact problem is the following,
    On a cold boot my backlight for the lcd never turns on anymore. I either have to connect to external monitor and toggle between displays to sort of force my computer to realize I need the backlight, or else fiddle with the laptop lid switch (either close and open lid lots and hope that does it, or else go directly into the laptop and manually toggle switch and mess with connecting plates in it (this latter has been the only thing to work recently). I am beggining to think it is not actually the switch but perhaps some problem overcoming an inital voltage threshold to light up the backlight?
    I have repaired my switch back to its original state in that I can close lid and the backlight goes out and open it and it comes on, but if I leave the screen dark for long, it fails to light up again...
My gateway gx 7018e doesn't come on when i press power button for about 2 hours then asfter trying several times a get a normal boot
Could be anything, power switch, power supply, motherboard, etc. Take it to your local computer store for diagnostics, may save your sanity.
Aug 10, 2010 | Gateway GX7018E PC Desktop
Circuit board
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 16, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Gateway 7510gx does not turn on. Replaced with new battery, no luck. PSU, I tested with a non contact voltage tester and tested ok.
My initial guess is that you have a problem similar to an issue I experienced a while back.<br />Does the light below touchpad come on indicating the laptop is plugged in when it is plugged in? If so the problem may well be simply the power button itself. This strip can be removed fairly easily and the button examined for issues. <br />To remove the strip (I am guessing warranty is up since its an old model, if not probably best to leave it to repair center):<br />remove two screws from the bottom of the laptop:<br />The two to remove are the ones one the edge with the hinges in the center. (There are a total of 4 screws along this edge, ignore the ones on either left or right edges). <br />Next with lid closed, press against the back of the hinge covers in their centers and lift. Pressing the center will release a catch on each and u need to then pull this up. I get a little seperation then gently wedge a screwdriver under them to help lift and pull out the catch. <br />With both catches released, open the lid fully (to 180 degrees). Be careful during this step as the covers like to snap back in place, it it helpful to keep them wedged out of place with a screwdriver or something. <br />With lid open, u can now pry under the hinges to begin to remove the strip above keyboard that has the media buttons and Power button. Once u work the hinges loose the strip should come off easily, but if not there are two catches along the top edge of the strip near the media buttons, if you use a screw driver to gently press down (towards keyboard) on these latches they will release without breaking.<br />Now the last thing to do is to note that there is a ribbon from the mb connecting to the media and power buttons. Note the orientation of the ribbon then, release the grip by pulling up on the plastic retainer (brown in my laptop). note this wont come off but will slide out a little. With the plastic retainer slid out, the ribbon will come free. <br />You can now take the strip and work on it. Flip it upside down and you will see screws for the circuit board for the media buttons and the power button. <br />You can then run some tests to see if the power button is closing the circuit as needed to actually trigger power up. <br />I hope that's all it is and that this helps.<br /><br />
Feb 26, 2010 | Gateway 7510GX Notebook
Won't drain
Hi..
To diagnose your solution you need to check this steps that i can provide you
  1. Check that the washer is plugged in securely
  2. Check the circuit breaker of fuse box. "A circuit breaker provides protection for each of your electrical circuits by stopping the flow of current if an overload or fault occurs. When an electrical fault occurs or the load on your circuit becomes too great, the breaker on that circuit trips and interrupts the flow of current to that circuit. A tripped circuit breaker is still sometimes referred to as a "blown fuse" in reference to the older technology that circuit breakers replaced. If your home uses an actual fuse and not a circuit breaker."
  3. Test the outlet for current. You can test an outlet to determine if current can flow with a voltage tester. Always test your test equipment for proper operation before use. If you don't have a voltage tester, simply use a shop light or other convenient electrical device. Start by making sure the tester is working and plug it into a circuit you know is working. Note that if you need to test a 220V outlet, these instructions do not cover that test.
If there is no voltage, make certain that the outlet isn't controlled by a switch. Try all nearby switches and check whether the tester lights up.
If you are troubleshooting an outlet that isn't working, some possibilities include:
  • The fuse has blown or circuit breaker has tripped. Click on the following links for more information on replacing fuses and resetting circuit breaker.
  • The outlet may be in a circuit with a GFCI outlet (ground fault circuit interrupt). If the GFCI outlet has tripped, it may cause other outlets on the same circuit to lose current. Look for an outlet that has a "Test" and "Reset" button. They are often located near water such as in a bathroom or kitchen. If the outlet has been tripped, unplug anything that may have caused the fault and then press the "Reset" button.
  • A wire connection has become loose. A wiring fault can occur in many places, the most common include the outlet box, another outlet or junction box the wire passes through or at the circuit breaker.
  • Outlets can wear out, a replacement may be needed.
4. Check that the water supply valves are turned on
5. Inspect the filter screen.
6. Test for overheating
7. Test the water level switch
8. Test the timer control
9. Test the lid switch
10.Test the water inlet valve
Good luck !!!
Regards
PCmania
  1. Inspect the water pump
  2. Test the centrifugal switch
  3. Test the motor
Jul 16, 2009 | Kenmore 24032\24036 Top Load Washer
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing Power Button Circuit Card on Gateway W730 K8X Laptop
The instructions for replacing the keyboard include the cover you have to remove to replace the power button pcb. The power button pcb is attached to the bottom of the bezel that covers the hinges/button array. In a nutshell you just remove the 2 screws indicated in the instructions, pry the hinge covers up a bit, then gently pry the bezel up from the bottom. remove the ribbon cable, pull back the small piece of tape, remove the three small screws holding the pcb on, and remove it from the spring clips.
Apr 11, 2009 | Gateway Computers & Internet
I need to access the BIOS on my Gateway GT5428 PC
well, the most common BIOS entry keys are F1, F2, F10, and Delete.
push one while the computer is booting, before windows starts booting.
Mar 26, 2009 | Gateway Computers & Internet
Gateway 503gr power switch
if you are a practical person, the power on switch is the crudest item ever on a pc. The switch simply completes a circuit. If you look on you motherboard at the front panel connector cables, you will see the two that go to the power on switch. remove them, flash a small screw driver across the terminals and it will come to life
Nov 03, 2008 | Gateway (4000474) Motherboard
I am using a Gateway notebook computer 7422 GX. The main power button on top of the keyboard does not work thus I cannot switch on the computer after I put it on AC power. If there other way of switching...
try this turn over the laptop and there should be a reset hole gently insert a non metallick item like a tooth pick works well in the hole and press it and try to press the power button and see what happnes if not you will have to have the button serviced see if you have a warantee good luck !!!!!
Aug 09, 2008 | Gateway Computers & Internet
Ariston washer
is this a new washer. if so remove shiping bolts from bottom or back.
Feb 15, 2008 | Washing Machines
Gateway 7510GX Notebook Logo
489 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
