Question about Air Hogs Reflex Micro Helicopter
I can dirvet - Air Hogs Reflex Micro Helicopter
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Suction is great, maybe too good. unit does not
Your probally right about the suction being too much. If you have a main drain and it get's stuck there you need to shut the drain off as the two suctions will stick to each other. If it get's stuck in random places then you just have to much suction to the unit. You can test by slowley pulling two of the hoses apart to let some of the suction escape. If this fixes it you can purchase a dirveter to mount where you mount the cleaner. Their may be one in the box your cleaner came in, so be sure to look there first before spending on a new one.Good luck.
Dec 19, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac Barracuda stops moving
Depending how you hook it up to the pool you need to be sure it is getting enough suction. If this is a dedicated line be sure that the valve is going all to the cleaner and back off till the pump quiets down. If you have it running through the skimmer be sure the dirveter valve is set to the proper suction and if you have a skimmer plate be sure your main drain is plugged off. Also check in the cleaner again. Things can hide in the diaprahm so be sure to use something that will let you go all the way beyond it or take apart to check if you have to. Good luck.
Dec 17, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
H400FDN... Lights... burns for 5 secs... turns off... repeats...
Pull your heat tray and clean burners and check for rat nests. A common cause of this is spider webs in the gas orfaces on the supply pipe. If you remove the brass orfaces they may have small,small,small tiny webs inside them oyu can blow out or clear with a toothpic. they dirvet the gas from the main burner (the one with the ignitor) as the gas builds it will poof and start but then the other burners that have gas flow won't be close enough to let the ignitor read flame so it will cycle just like you describe. My kingdom for a toothpic. I have made a tool to do this out of a stripped wire bent just so with the end roughed up to catch the webs so I didn't have to pull the tray on heaters with this proble. You should pull the tray and see the whole problem to understand it better.. I hope this helps and good luck.
Oct 02, 2009 | Hayward H Series Pool & Spa Heater 400k...
My Zodiac Pacer seems to get stuck. There is suction (pretty strong). It can happen on the side or floor of the pool. If I pull it off, it starts going again, it's like there's too much suction or...
It probally is to much suction. You should have a dirveter valve where it hooks to the wall or the skimmer. This should have come with the unit and your manuel should describe it and it's function for you. if you don't have one your local pool store can help you out as these are generic in most case's.
Sep 30, 2009 | Zodiac Pacer Pool Cleaner
Air Hogs Reflex Micro Helicopter Logo
59 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
