Question about Amana ACD2232HR Side by Side Refrigerator
Amana Side by side refridgerator Model SBD20TPE P1190006WE
Hi, we bought a house with the above Amana installed. It's a stainless steel side by side with water/ice dispenser on the left side. Two months ago, the water dispenser was dripping/leaking in the off position. We couldn't find the cause and ended up clamping the supply line that we could find underneath the fridge, so now we have ice dispensing but no water. Yesterday, I heard a "PSSST' sound and found water spilling out of the fridge. We removed the drawers and found a leak in the plastic unit on the lower back of the fridge (inside, under a white cover). We tried everything to stop it and ended up clamping that line, to prevent the water from coming in.
1. Any idea what might be wrong (esp with the fridge leak)? The temp of the freezer and fridge is still fine.
2. Is there a cheap way to repair or some things we can try
3. Does the water do anything in the fridge beside help the ice maker/water dispenser to work? We hoped that was it's only purpose, and can live without that.
Thanks much!
  • nazzery May 12, 2008
    We have a similar problem. Water will just start coming out of the water dispenser for no reason.
    Problem Solver:
  • 6 Answers
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: :
Posted on Jun 05, 2008
Whirlpool refridgerator side by side is leaking water on the side. We do not know where it is leaking from
Often water leaks result in stains on the Stainless Steel, use DeBruce Polish for removal. Using DeBruce Polish on all your stainless steel will allow you to now perform JUST TOUCH UPS of finger printing and remove the need for "OILS" that manufacturers provide for cosmetic care of blending. Stainless IS A GREAT FINISH TO CARE FOR one just needs the right product. Once cleaned with DeBruce Polish there exists no oil or other "films" to BLEND. DeBruce Polish will now perform touch ups instantly. LOVE YOUR STAINLESS STEEL AGAIN! Get DeBruce Polish at NON-TOXIC AN ODORLESS ...PERFECT
Jan 06, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator ice machine rotator rod is not turning
Jul 17, 2013 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hi there, need help replacing defrost timer in my ge gsh25jstss refridgerator
What is the age of the refrigerator? GE usually mounts the timers behind the kickplate in front.
Feb 03, 2011 | GE GSH25JSTSS Stainless Steel Side by Side...
I have a stainless steel Amana model ABC2037DES that was given to me. It has been plugged in for 24 hours and it is not freezing anything or making ice. The refridgerator is not cold enough either. ...
if the compressor is working it could be a thermostat problem
I think that if you check for a reset button at the back to get the compressor running , that will fix the problem
Mar 13, 2017 | Amana ABC2037DES Stainless Steel Bottom...
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Side by Side Stainless steel Ice Maker water will not shut off
The fill valve may hae a chunk of debris such as rust in it. If you disconnect power and water, you might disassemble the valve if it's the type that was screwed together. If it's riveted, you'll have no choice but to replace. In either case, make sure you have a filter in the line so this does not happen again.
May 18, 2009 | GE Refrigerators
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Frigidaire the refridgerator is not cold enough. It stays at 60 degrees, I don't know the model because it was torn off inside the fridge and the owner's manual did not come with the house when we bought...
Have one similar and found out the compressor goes out on them about a year and half after purchase. You can buy another compressor but the likely hood of it going out again is likely. Sorry but we bought bad fridges. Never again will I buy a Fridgidaire.
Jun 10, 2008 | Frigidaire Refrigerators
Amana Refridgerator Freezer, French Doors
Most side-by-sides have a length of hose at the bottom of the freezer that send the water to the ice maker and water dispenser. take the back off so you can see this hose, there may be a kink in it, or a clog.
May 30, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana ACD2232HR Side by Side Refrigerator Logo
208 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
