Question about Kodak Office Equipment & Supplies
I have an Ektagraphic, but can't determine the model. It is from about 1972. Can send photo if you need. Remote focus stopped long ago. Now it no longer does forward and reverse.
    President:
  • Kodak Master
  • 412 Answers
Kodak manufactured an "Ektagraphic" model (without a suffix) from 1969 to 1971. Remote focus (given the age of the projector, I wouldn't bother repairing it) is more trouble (and $$) than it's worth. The forward / reverse problem is pretty straightforward: the "link" between the cycle solenoid and the slide change mechanism is probably broken. It is plastic and gets brittle & cracks with age. It will require an authorized warranty repair dealer to fix it.... who knows, maybe they will throw in the remote focus for free !! :)
Posted on Nov 03, 2010
Fix focusing on ektagraphic remote control
Ektagraphic III A did not have remote focus. Someone has probably substituted a remote from a higher functioning model on this projector. The forward / reverse functions on the supplied remote will continue to function correctly, but the focus buttons will not.
Good Luck !! Jim
May 20, 2014 | Kodak EKTAGRAPHIC III A Slide Projector
Fix remote focus on ektagraphic projector
The problem you describe on your Ektagraphic ATS could be caused by a couple of things:
1> You have the incorrect remote. You need the correct remote for the remote focus over-ride to function. Just because the "Focus" button is on the remote, doesn't mean you have the correct remote control. The remote control could be broken, as well.
2> You could have a broken or mis-adjusted focus over-ride switch inside the projector. To rectify this you may need special tools and/or parts ( I'm not sure they are still available). To check this, contact: www.micro-tools.com
Micro-Tools may be able to provide you with instructions to make the repair, as well as the parts. Good Luck!! Jim
May 20, 2014 | Kodak Ektagraphic III ATS Slide Projector
Kodak ektagraphic slide projector wont turn on
Hello, We may have to dig in the archives for this one but I will give it my best shot !!!! The unit has a main fuse, one of those glass types. It sounds like it blew the fuse. You may need to have this unit serviced by a repair shop. If you replace the fuse make sure it is of the same amp rating as the old one !! This is very important as to not start a fire.
Best Regards, Russell
Jan 04, 2013 | Kodak Ektagraphic Model B-2
Kodak Ektagraphic AF -2 carousal not rotating
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Nov 28, 2012 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
Need remote code for Zenith tv model no tvbr1942z
I got code 21479 to control power and channel up/down but it won't manage volume. That code also pulls up the menu for the TV too. Could not determine VCR compatibility since the VCR died ages ago.
Sep 22, 2009 | Zenith TVBR1924 19 in. Combo
Auto focus and manual focus(red+will not move left
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 17, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Need wiring schematic showing fuel tank to gauge in 1972 chev trk
There should be a wire that connects to the gas tank sending unit and maybe another wire connected to a spade terminal that could be screwed down to the in-tank sending unit. The brown wire from your gas tank sending unit goes to the back of the dash guage. All the gas tank sending unit does is give a "ground" signal to the dash guage. Whatever you do, do not connect the brown wire to a positive 12 volt wire as sending 12 volts through the gas tank sender will explode the gas tank! Take a look at this website and it will all clear up for you.
http://auto.howstuffworks.com/fuel-gauge1.htm
You did not say if your dash guage is wires with a plug-in or single wires connecting it. If what i've given you here is not enough to fix the whole problem then respond back with how does the wires connect to the back of the guage. Good Luck!
Jan 13, 2009 | Chevrolet 1972 Blue & White Chevy Pickup...
My binoculars are Zeiss 8 x 30 Jenoptem purchased new in 1972 £24.99 retail. Still in excellent condition until I dropped them on the carpet a few days ago. I now cannot focus them properly resulting...
In the UK your best bet would be to send them to Kay Optical. They have an enviable reputation in repairing binoculars. Another place in the UK is Cley Spy in Norfolk who also have much experience with older optics.
Sorry neither is too close to you.
Jul 02, 2008 | Zeiss Classic 524006 Binocular
Pantech phone won't send photos
iI think your mms setting was have some problem, you can just check or reset it or call to your service provider for more info
Jun 04, 2008 | Pantech C300 Cellular Phone
73 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
