Question about Frigidaire Washing Machines
Washer won't spin. If washer is placed on the spin only cycle it will sping sometimes and sometimes it won't
    President:
  • 1,554 Answers
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replace the door lock and switch assembly to address the issue. Indicate the complete and exact model number of the machine for the right replacement part number.
Disconnect power to the machine then open the washer door and look for the retaining hoop securing the door seal around the lip of the door opening. Use a pair of long-nose pliers to grasp the wire hoop at the spring location and expand it to clear the door gasket and remove the spring and wire hoop.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Washer won't spin. If washer - 1a4b866.jpgttp://i.fixya.net/uploads/images/1a4b866.jpg" alt="1a4b866.jpg" class="h_mi" />
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door Washer won't spin. If washer - febd08e.jpgitch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop to complete the procedure.
Indicate the complete and exact model number of the machine should you need further advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 23, 2010
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Not spining- water standing can't get water to
    If your washer is not spinning ! You first need to drain it. Then underneath your washer you will find your drive system. It will consist of drive belt, drive pulley or pullies and motor. Belt could have come off , if so check the condition before reinstalling, also some times from overloading the belt will spin on the pulley which will make it hot and thanks to the manufacturer the pulley is likely plastic. Parts supply shops best source for belts and possibly pulley though sometimes they want to sale you the whole motor with pulley which you don't need. If so uae internet to find your pulley probably under 10.00 dollars. Hope this helps.
    Feb 23, 2010 | Kenmore 23822 Top Load Washer
    Washer will fill fill with water but doesn't start wash cycle
    it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
    Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
    Danby front load washer Will not spin motor runs
    If the "Spinning Off" button is pushed in you will get this problem.
    It happened to my wife last week.
    If the drum is turning the belt is OK
    Jan 25, 2009 | Danby DWM5500 Front Load Washer
    Kenmore 80 series makes noise in sping cycle
    Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
    Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Zanussi aquacycle 1000 washing machine spin problem
    this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
    May 29, 2008 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    255 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
