Question about Panasonic Televison & Video
I have a Panasonic PT-60LC14 and the HDMI is not working. The DVD which uses separate input works fine. I have changed HDMI cables with no improved effect. When the TV is HDMI mode, there are white letters that spell DBS, as normal. I have tried connecting it to both a DirectTV box, and a PS3. What could be the problem?
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
Heiny
  • 10 Answers
SOURCE: PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Posted on Dec 17, 2007
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
thecritter
  • 29 Answers
SOURCE: I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
Posted on Mar 17, 2008
SOURCE: Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Posted on Mar 13, 2009
My Insignia Blu-ray DVD player and our Panasonic DVD player are playing only the sound with no picture. We put the correct imputs on the TV. They were playing fine a few days ago. We have Charter cable....
Sounds like the input board on the tv fried. (45-65$ fix if that's it)
Try the same two devices on different inputs , ie change from hdmi to component , or just use hdmi 2 instead of one, you get the idea.
Make sure the devices dont work on other inputs on the tv.
Then take a different device , like a 3rd dvd player and try it.
If nothing works in that input but works in other inputs the tv input board might (likely) need replacing.
If the third fresh device does work in that input , it is both dvd players or the cable you are using. (try to use a different cable in the tests than the one you have already used. )
Feb 13, 2018 | Zenith DVB312 DVD Player
Tip
Panasonic PT60LC14 Manual Download
Download Panasonic PT-60LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-60LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-60LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 27, 2010 | Panasonic PT-60LC14 60" Rear Projection...
Tip
I hope that helps.
on Apr 27, 2010 | Televison & Video
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 17, 2014 | Panasonic PT-AE3000U LCD Projector
PS3 wont display using HDMI ports and Input connection on PT-52LCX66
It would seem either a setting at the ps3 or the set is not right.
Good idea to check all inputs and setup again--if something like a DVD works on rear input issue is with the PS3.
Mar 14, 2012 | Panasonic PT-52LCX66 Projection Television
Hdmi inputs does not show a picture. The inputs just stop working.
I'm having the same problem. The projector stopped recognizing any input over either of the two HDMI inputs. The JVC RX-D411S receiver was working fine up until I used the VGA input with a computer and since that time, HDMI has not worked (despite working fine before). I tested two HDMI cables into each of the two ports but nothing! All other inputs work fine.
Jun 28, 2010 | Panasonic PT-AX200U Projector
Horozontal balck line across the middle of the screen
also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Mar 12, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Apr 13, 2008 | Panasonic PT-AE900U Multimedia Projector
HDMI Signal gone
Aug 24, 2007 | Panasonic PT-52LCX65 44" HDTV
Televison & Video Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
