Question about Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38 Self Contained 115V Flake
Ice o matic ice machine model# ice0500ha1 need dip switch settings for unit all were @ the off position upon purchase due to previous owner tinkering with unit
  • Joe Palazola Jan 05, 2011
    Are you sure this is a flaker? The models that start with ICE are all cubers as far as I know.
How do I adjust bridge thickness on ice o matic
Adjust the Timed freeze. The freeze timer is an adjustable timer used to control the ice bridge thickness. The freeze timer is factory set but may need to be adjusted upon initial start up of the machine. When time is added to the freeze timer the length of the freeze cycle is increased, therefore the ice bridge thickness is increased. When time is removed from the timer, the freeze is shorted and the ice bridge thickness is decreased. The freeze timer can be adjusted by sliding one or more switches to either the ON or OFF position to 1/8'' ( 3mm ). If bridge is too thick remove enough time from the timer to achieve proper thickness. If bridge is to thine add enough time to timer to achieve proper thickness.
NOTE: The freeze timer on ECP models is located on the circuit board. It operates and is adjusted as described above. Now if you have had this machine for awhile and it was making the right bridge thickness and is now making thinner ice i would look at the purge valve to make sure it is not letting water seep out of the sump tray during freeze cycle this will cause the sump tray to keep filling up with water and will cause thin ice.
Sep 15, 2014 | Kitchen Appliances - Others
I have a ice-o-matic 400ha2 ice machine that is not making much ice and is to thick. the timer has been replaced,but no change
reduce the thickness thermostat that initiates the timer to minimum, then increase until good ice made.
Aug 29, 2014 | Kitchen Appliances - Others
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
To big of icebridge
The ice bridge thickness of this machine should not be over 3/16" check the harvest assist solenoid and plunger during harvest to make sure it is operating. also check freeze cycle controller you will see it has some dip switches with off and on above the switches with numbers to the side of them you can take some freeze time out by starting at the top and moving the switch to off then let it make a batch of ice to see if this made a difference. The less time the thinner the ice. Time added to the controller the thicker the ice.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice machine making cloudy ice
ice maker may need cleaning, filter and/or scale collector changed. IF there is no water fiter you should add one.
Jan 23, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
WHERE CAN I PURCHASE A CHEAP NEW OR RECONDITIONED COMPRESSOR FOR MY ICE MACHINE? tIMES ARE HARD AND I CANNOT AFFORD THE $600 FOR A NEW ONE.
Hello Smokinjoex5,
I need to know a model number of the unit in question. The model number should be located on the rear of the unit and/or the numbers off of the compressor. You do understand that you will still need to have a service tech come and install the compressor as this is not something that you can do, you have to be a licensed HVAC service tech.
Post back and I will try and locate you a compressor.
Thank you for choosing FixYa.com
Justin
Apr 19, 2011 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
ICEU150 bridge thickness time delay to 1 second and the bridge thickness is still to thick
The bridge thickness on this model starts with the low pressure cut-in control that then in turn starts the timer. It sounds like you have either a bad low pressure control or one that has been tinkered with. To start with if you have a low pressure gauge that you trust what I do is take all of the time off of the timer and unplug the water pump. Then start the unit and watch the low pressure gauge to see at what pressure the harvest starts. an ICEU150 with R-404A should cut in at 44psi. Once that is set plug the water pump in again, put about 400 seconds on the timer, see how thick the ice is after 2 cycles and adjust as needed.
Jun 09, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
I have a model number of EC200HWPB1 and i am not
i think it might be located on the panel at bottom were warm air blows out an sucks in cool air...remove the screws...or on back of machine...hope this helps.....good luck/
Apr 03, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38 Self Contained 115V Flake Logo
214 people viewed this question
Top Ice-O-Matic Kitchen Appliances - Others Experts
Justin Hall
Justin Hall
Level 1 Expert
Marat Brikov
Are you an Ice-O-Matic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
