Question about Frigidaire Affinity ATF7000E Front Load Washer
ERROR CODE 68 ON AFFINITY ATF7000EE
I HAVE A ERROR CODE 68 ON MY AFFINITY ATF7000 WASHER,WHAT DOES THIS CODE MEAN.
  • 240 Answers
Check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
Posted on May 04, 2008
Why is my affinity dryer not heating and showing error code 56
Good Afternoon Friend,
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Error code e68
I understand you are receiving an E68 error code on your Frigidaire Affinity washer, model# ATF7000E. The E68 error code states that there is a possibility something is going on with the heating element inside your washer. It could also be a false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on the hottest cycle on a heavy soil level. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Affinity washer flashing EFO
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
The door locks for a few seconds, then unlocks, and nothing happens. The door lock light goes out. Code E-68
Code 68 = Current leakage to ground on heater or fuse opened.
It can be a bad heat element, possibly a loose wire or as has been reported before, the insulation on the wire has fraed and is grounding againt the metal washer casing.
Unless you have a good electrical background, I strongly suggest calling an appliance professional to come in and fix it.
Nov 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
I have a front loading washer and it was flashing an error code "EFO' What does that mean?
I just spoke with customer support for my Affinity. They told me it was over sudsing (sp?). from using too much soap or not using high efficiency soap. Suggested running thru a cycle without soap to clear things out.
Aug 09, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
493 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
