Question about Health & Beauty
I have a milky looking secretion slowly coming out of my pennis for the past 12 hrs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
You must go see a doctor
Posted on Aug 24, 2010
My Drayton lp522 clock is out by 12 hrs instead of 21.21 it reads 2.20am
Move the setting past 2.20 am so it switches to pm and set it for the pm time you want. You may have to operate a 12 hr/24 hr switch to get it right.
Nov 13, 2016 | Home
How do I get my electric usage in Kilowatt hrs for the last 12 months?
For total usage, look at your past electric bills.
If you are looking specifically for use by your AC - we will need to know make & model to advise you.
Jan 06, 2015 | Heating & Cooling
2001 YAMAHA ROYAL STAR 1300
If the coolant is a milky brown, you have some oil in the system. This could be a failed head gasket or it could just be some rust in the coolant. First you should drain and flush the coolant system, then refill with fresh coolant(to the spec that Yamaha recommend) If the problem persists after a short period of riding, then you probably have a failed head gasket.
Jun 04, 2013 | Yamaha Royal Star Tour Deluxe Motorcycles
My ps3 keeps frezzing through games
if its freezing while reading, it maybe your rsx chip is beginning to spread apart from your motherboard.. how old is your unit.. first try cleaning your lens before purchasing one.. if you have to purchase a lens check ebay against CECH model(CECH-2501A, CECH-K01) then see what the return policy is.. NO RETURN, 3 DAYS, 10 DAYS.. if that lens doesnt work for you return it quickly, chances are your lens is still good.. then you will have to look into the heat gun 4 penny trick.. if its under warranty($150).. out of warranty the cost to fix is roughly $50.. if you dont have the tools already around..
home depot- has a heat gun in the paint department for $22..radio shack- ceramic thermo paste $8 or artic silver thermo paste $12..
radio shack- home depot- percision screw kit $12and last but not least $.04 from your change and an hour of your time..
find a you tube video to help you disassemble your unit
http://www.youtube.com/watch?v=BhagHRSTd5I&feature=related
i copy this guy, movement for movement.. each time i fix freezing/ ylod/ rlod/ glod/ black screen units.. i use a painters Wagner yellow heat gun unit on high..
http://www.ps3iso.com/ps3-tutorials/77803-play-station-3-green-light.html
spreading thermo paste- should be a little thicker than a sheet of paper covering entire video chip and cpu chip..
place the four pennies touching side by side forming a square in center of the video/RSX chip only.. i dab thermo paste in the center of pennies, dont bother spreading..
MY KIT: Power drill for case only/ unscrew only.. empty ceramic package is perfect for a screw container.. piece of wood i drilled a hole thru wood for the power prongs to fit thru from motherboard.. wood is to protect other surfaces from heat.. $8 ceramic2 from radio shack.. 7_7_2012_9_16_13_pm.jpg
Jul 07, 2012 | Sony Playstation 3 (PS3) Console
The car stops suddenly, after slowly losing power. Started up again, to move off to side of road. No longer started after that. checked oil, it was milky looking, so we changed it. checked the battery, it...
sounds like the head-gasket blew, and the fuel pump may have gone out. I would really have to be there to know for sure. I guess you need to see if you have spark, and if fuel is coming to the engine, may have had a fuse or two go out, also. Good Luck Tim
Oct 23, 2010 | 1996 Chevrolet Blazer
I have an older quasar tv and it has a game lock code and a channel lock set to 12 hrs. I bought this tv at a pawn shop and dont know the 4 digit code is there anyway to reset the code or a master reset...
No,there no reset codes for personal secret codes,even the technician wouldn't able to fix this problems,might fix this problems by replacing Tuner board,but than it not worth the price of the tv,if u do that.Sorry u have to take the problems u have it with this tv.
Apr 30, 2010 | Quasar SP-3235 32" TV
1984 chevy G30 5.7 350 engine problems
Sorry to say that the head gasket was blown. Coolant already mixed with oil to generate that milky thing. There is no power since there is not compression due to the leak going through the head gasket.
Apr 25, 2010 | 1984 Chevrolet Sportvan G30
XBox 360 Steady Center Light at bootup No Green flashing Lights.. After a few moments RROD.. RROD Fix Applied and redone several times.. Even used the Penny Reflow method on both Chips.. Any other options...
First, the Penny reflow, is worth exactly what it costs.. next to nothing.
Depending on which RROD fix you are working, depends a great deal on the success you are having with it.
Now many look at what is being sold, jot down the screw and washer sizes and head out the door. to the local hardware store. if you are lucky you happen to get the same stuff.. but more likely, there are variations. the screws are a bit longer or shorter.. the washers are thinner or thicker..
But the biggest thing is. besides changing the clamps, and the thermal paste, it isnt doing anything to correct the issues that were set in motion in the first place.
Before the first red ring happend you were slowly heating up components, and the heat from that was affecting the motherboard, the weight of the x clamps hanging underneath can add to it,causing it to warp. the warping of the boards affects the solder that holds the chips on the board and affects the connections.
Thats why the the fixes you have been trying are falling short. The penny tricks were short term if at all, by pressing down on the HANA chip, and most likely completing the circuit that has failed.
The only way back is a reflow of the chips, the GPU, the HANA and the Southbridge Esp.
Now depending on how confident you are in this, look for more info on how to reflow your xbox360
The best place to look for more answers:
http://forums.xbox-experts.com/
Mar 14, 2010 | Microsoft Xbox 360 Console
St. Gabriel grub control - Purchased 20 lb. bag
In terms of grubworm control, 'milky spore' products are bacterium meant to create a long-term soil-borne epidemics amoung grubs in the soil. Milky spore very likely will not kill existing populations that're eating at turf roots & thus, doing damage.
But milky spore is an environmentally-conscious product, and certainly a wise long-term investment for those who've put a lot of investment in their lawns.
In leiu of milky spore, I recommend any product containing Dylox for active infestations.
Milky spore may be applied in that same season in an attempt to start that longer-term, human & pet-safe grumworm contagion.
It is perfectly normal to see small numbers of grubs in the soil, in both turf & landscape. In small numbers, grubs are generally harmless. The concern mounts when their numbers are higher.
This is how to check for actively feeding grubs:
In turf areas that are turning brown, get on your hands & knees and take the turf into both hands, and pull.
If the turf readily comes up as if it's carpet, you'll likely see the "lawn shrimp" (haha) underneath.
In a 12" x 12" section, if you see more than 2 grubs, it's time to take action.
Answers:
1) No. After applying Dylox & watering in per instructions, wait approx 1 week to 10 days, then peel back some of those sod areas again.
If it's working, the grubs will have slowly turned from an ugly grey to a light beige, and shrunken somewhat.
2) No. Moisture on grass at time of application doesn't matter. What matters is that you irrigate thoroughly AFTER application.
3) Actually, it is to your advantage if adjacent soil areas aren't treated with milky spore. If ALL grubs are killed, then there will be no carriers to continue the bacterial contagion. Even if your neighbors are grub-free, keep in mind that Japanese, June beetles, masked chafer, etc will drop eggs into the turf season after season. (There's nothing you can do about that.) And these eggs will eventually metamophecize into grubs. If you have milky spore in the soil, they shouldn't mature to the point to which they'll feed.
4) Products containing Dylox are labelled to kill grubs of all species of beetle. At about the time you're seeing June beetles swarming your back porch light, they're likely laying eggs in the turf. Most species of grubworm potentially can do damage 2X year:
JUST before the adults emerge, and about a month to six weeks after the maximum height of adult population.
Here in s. Ohio, late September thru first ground freeze tends to be historically the worst peroid for grubs. But some years, mid to late spring damage can be found, too.
Sep 27, 2009 | St Gabriel Laboratories Milky Spore Lawn...
Warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Sep 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Health & Beauty Logo
20 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
