Question about NetGear WGT624 Wireless Router
Wireless LED no Lit - No wireless network
WGT624v3 wireless LED no longer is lit and wireless network no longer works. Can this be reset/fixed?
  • sldr Aug 29, 2008
    wireless LED not lit. No wireless network.
How can i setup the wireless
Posted on May 04, 2008
Blue wireless not flashing
Seems the cable is not working. Try to find another cable.
May 24, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
How do i reset office jet 6500A to wireless setup
Do you need the wireless reset on the printer or your computer? On the printer you will see the blue LED lit up when it is on and that should mean that it is transmitting. If you are not able to connect to it on your computer you can uninstall the HP software and re-install it. Not a great option, but it always works. Also, make sure that your printer and computer are on the same wireless network.
Hope this helps!
May 15, 2014 | Computers & Internet
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Im trying to connect my dell xps m1710 to my new provider talktalk but its saying my wirless connection is not available where do i switch it on and how
The wireless LED will be lit if the Wireless connection is turned ON. Please check the LED indicators that are available below the LCD and check if the Wireless indicator is lit. You can enable the Wireless connection from the Windows Mobility Center too. Open the Control Panel and select classic view and you can find the Windows Mobility Center. You can find "Turn ON wireless connection" there. You can also enable the Wireless connection from the Network and sharing center.
Jun 19, 2010 | Dell Computers & Internet
Ethernet lights 1-4 are lit, wireless light out
wireless light will be ON only if you have connected any wireless devices to your network... security light will be ON only if you enabled password to connect to your wireless network.... if you have changed any settings in the router recently, then delete the saved list of networks in the computer.... then search for wireless networks in range and connect to your network....
Apr 19, 2010 | Linksys WRT300N Wireless Router
Okay...on my router, the wireless connection light is not lit up, and the network is not showing up. I have already set up a network, but it is not showing up...help please.
Check if the SSID broadcast on the Wireless Router is Enabled or not.if its Disabled then the Wireless Network name will not show up and if the Wireless Light is not lit up on the router then you might need to reflash the firmware on the router, reset it and reconfigure it back.that should work in your favor
Mar 17, 2010 | Computers & Internet
Wireless light not lit
The wireless functionality of the router is no longer working. The light is always turned on on all wireless routers
regards
Sandeep
Nov 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
122 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
