FixYa.com
Tags:
Sony VPL-HS20 Multimedia Projector
VPL-HS20 issues...who's got the right answers!
posted by Malibu Stevi on May 04, 2008
Hey all and thank you for setting up such a great website for us fans of Sony products!
I have an issue with my Sony VPL-HS20 projector and would love to know 2 things. I'm now to using projectors and hope it's not too late to get some much need words of wisdom.
I received a message sometime ago saying the the filter needed to be cleaned whcih I dismissed from the screen hoping that it would appear at a time when I didn't have guests over to watch a movie. I have not seen it since and would like to know how to best go abouts doing this.
Also, my projector is making a horrendous noise when I turn it on and seems to be coming from the fan on the side where the control buttons are. Has anyone else experienced this and know how to deal with it as I'm a bit worried.
What is the best way to take care of a projector in terms of cleaning and routine maintenance?
Any help and advice would be much appreciated.
Thanks for reading and keep up the amazing work!
Stevie.
Comment by Malibu Stevi, posted on May 12, 2008
Thank you so much for your prompt response and please accept my apologies for the late reply, just been very busy working!
Am in the process of finding out how much it will cost to have my projector serviced so it will help me resolve the issue of a bit of manual maintenance however, to help eliminate the issue of the unusual buzzing, am I correct in understanding that I keep the whole unit where it is and using the nozzle of a vacum, **** out any dust which may be there...if that's the case then that's a genius idea and never knew that such a thing is possible!
Or are you saying to remove the filter out completely and then vacum? I'm just a wee bit puzzled but hope that it will be taken care of soon as I miss my movie nights in!
Many thanks once again, Stevie.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 06, 2008
Not Rated (0)
Marrie
Rank:Wiz Wiz
Rating: 84%, 245 votes
Hi Malibu Stevi
To get the best time out of your Projector and your lamp , you should take in your Projector at least twice a year for a service.
If you want to clean out the filters , simply take a vacuum cleaner and vacuum the dust out.
As for the fan , this could be as a result of dust , but I would suggest you have it checked out by a Sony Service Provider as fan malfunction is the biggest cause of lamps blowing.
Also try not to run the Projector for short periods at a time as this simply eats away on your lamp. Rather leave it running for longer periods a Projector's lamp is similar to the lamp's you use in your house - switching on and off all the time makes the lamp's fillament weak - Take my word on this , I've had please using the Projector to watch a odd movie now and then and they only get 500 - 1000 hours on their lamps. And then I've had clients who use their Projectors as TV's and they got 10 000 - 15000 hours on their lamps.
Hope this is of help and thanks for using Fixya !
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
Screen is turning blue
My screen is turning blue so I... Answer This...
VPL-HS20 shuts down in the...
I get no message on the screen.... Answer This...
when I turn on my projector... Answer This...
periodic display on screen...
a movie camera icon... Answer This...
SWITCHES TO MEMORY STICK
when viewing on component... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
