Question about Stoves 720EF Electric Double Oven
My Stoves 720EF oven blows the trip when cooling fan stops
  • 250 Answers
The fan timer printed circuit board controls the cooling fan and there is also a resistor on the terminal block of the cooling fan. One or both of these could be suspect. If the fan still runs, then the resistor hasn't gone open circuit and is still providing continuity. The only way to prove out the circuit board would be to change it, but that could be expensive especially if it doesn't cure the problem.
Posted on Sep 11, 2010
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
When we switch the oven off the centrifugal blower continues as it should for a while then as soon as it stops it trips the circuit breaker in the house. I would be glad if you could help to identify the...
Someone else had the same problem. The cooling fan motor insulation appears to be breaking down due to heat/age etc. In the Stoves the fan is secured to the oven by a metal bracket. What I should say is that it appears you need a new cooling fan. However, the solution he came up with was to manufacture a bracket out of something that wasn't metal and heat resistant and replace it and it worked. I would only do this if you new what you were doing!
Dec 08, 2010 | Stoves 720EF Electric Double Oven
My stoves 720ef oven keeps cutting out after 20 minutes and will not turn back on, the grill continues to work ok. I know the timer is set to manual so I guess it must be a thermal trip. As I do not have a...
There are seperate thermal (overheat) cutout devices for both the top and bottom ovens. First check to see if the lower oven fan is running ok and is not restricted by grease or fat (there are 4 self tapping screws that hold the fan cover on) and the thermostat is switching off and on as it should. You should also check that the main background cooling fan is running and switches off a few mins after the ovens have turned off. If these check out ok, then it is possibly the lower oven thermal cutout.
Aug 04, 2010 | Stoves 720EF Electric Double Oven
Main Oven fan stopped and not getting hot
When you say stopped, is it just the oven fan and the cooling fan is still running? Is the oven control knob still lit and is the main oven LED on?
Is the time set on the clock and is the clock set to manual?
Dec 28, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF - main fan not working
When you say the main fan, do you mean the background cooling fan or do you mean the circulating fan in the bottom oven?
Do you have the handbook for this oven as the wiring diagrams are included in it. If you haven't, you can take a copy from my BT Digital Vault - all I need is an email address to register you.
Looking at the diagram, the power for the cooling fan comes via the timer board. If, as you say, the fan doesn't work at all, the timer board could have gone faulty.
Nov 15, 2009 | Stoves 720EF Electric Double Oven
My stoves 720ef oven goes off if it turned up over 140 deg c also the grill in the top oven does not get red hot
Is the cooling fan running in the oven? Does it also continue to run when the oven controls are turned off to let the oven cool down?
There are ventilation grills below each door on the oven. You can see these when the doors are fully open, just look under each door to see if they are clear and not blocked up.
Jul 21, 2009 | Stoves 720EF Electric Double Oven
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Stoves 720EF Electric Double Oven Logo
236 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
