Instruction Manual for Drayton Tempus 7 Programmer
4 Suggested Answers
comfortgurus
  • 10 Answers
SOURCE: I want to download a
Not sure where that document is on this site, but we were able to come across some instruction sheets on the Drayton Controls website:: http://www.draytoncontrols.co.uk/WorkArea/DownloadAsset.aspx?id=10467
It's not a ton of information on the product, but does offer some technical help.
Hope this helps,
ComfortGurus.com
www.comfortgurus.com
866-519-2461
Posted on Oct 19, 2010
  • 30 Answers
SOURCE: drayton digistat 3 instruction manual
http://www.firexsafety.com/NR/rdonlyres/BB812DC6-72D7-4B62-A142-9CAEF201B79E/0/Digistat3Instr2.pdf
Posted on Nov 14, 2010
  • 105 Answers
SOURCE: We have inherited a brown/beige
The instruction manual for this control unit can be found here:
http://www.heatingcontrolsonline.co.uk/instructions/Tempus7Instr.pdf
Hope this helps,
Chris
Posted on Mar 01, 2011
Testimonial: "Thanks. Link took us to more modern version, but provided phone # for Invensys. They were most helpful and, hopefully, will email what we need."
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Got 5 year old drayton tempus 7 when i try to put the hot water on the main electrics tripout ,heating is working fine tho'
my very first check would be the thermostat on the hot water cylinder, you may find you have a water leak on the cylinder which is dripping onto the thermostat. (quite common) another check and this is very dependant upon your skills is to check the wiring to the timer.
Sep 04, 2011 | Heating & Cooling
We have inherited a brown/beige Drayton Tempus.seven wall control unit for heating/water but do not have an instruction leaflet on how to rest it etc. Any ideas where we could get even a copy please
Hope this helps,
Chris
Mar 01, 2011 | Heating & Cooling
Can I get hold of a drayton digistat3 instruction book
Hi and welcome to FixYa, I am Kelly.
You can download the 2 page manual here:
Thanks for choosing FixYa,
Kelly
Feb 23, 2011 | Dayton Heating & Cooling
I want to download a Drayton Tempus Seven instructions manual< where is it on this site?
Hope this helps,
ComfortGurus.com
866-519-2461
Oct 19, 2010 | Heating & Cooling
Want a owners manual for Drayton Tempus Three Water heater
The Tempus three actually the controller not the heater itself. It varies from when the unit was made but I see the web littered with people trying to get this info. I trawled the net for a while to try and get a link for you but my best suggestion it to either email Drayton or you can find vartious instructions for the tempus 7, 2 and 1 that might help you figure out how to use yours. I'll keep looking and see if I can get a pdf. put on.
Aug 01, 2010 | Heating & Cooling
Drayton tempus seven
I have jjust found a manual for this system. The unit has a plastic cover on, which is not that obvious first. After opening the cover there are some buttons ( i.e. Clock). First press clock and re-set correct time. Then just press the relevant button ( i.e 1st on to set the time for having the heating on first thing etc. For each day, afert pressing Day button, the same can be set.
I think the key is to realise that there is a front cover, which hides the buttons. Hope this helped.
Oct 12, 2009 | Dayton Water Heaters
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
I've a problem with my central heating, I've changed my central heating programmer to a drayton lp522. My heating is constantly on. The only way that I am able to turn it of is with the thermostat when I...
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Dec 03, 2008 | Water Heaters
Heating & Cooling Logo
940 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
