Question about Savin Office Equipment & Supplies
I have a savin copy machine Model 9032 and error code U6 is on what does that mean?
SOURCE: Savin 4090 error code
hi this code means they are no toner in the toner hopper which is attached to the developer unit. hope this helps.
Posted on Jul 26, 2008
  • 97 Answers
SOURCE: misfed paper jam in section
- Double check if they have paper inside the machine
- check the tray and other open doors.
- clean all sensor area.
Posted on Sep 22, 2008
SOURCE: copier error code
Unfortunately, that is a Polygon Motor (Laser Unit) error. It means the laser is not starting up, which means it is shot. At this point it might be difficult, to source the Motor, if not more expensive than it's worth to bother fixing this unit.
Posted on Mar 16, 2009
SOURCE: "Updating the destination list has failed" Error message on Savin
It is a communication problem that's all.
I may or may not be able to help.
Are you using a scanning software on your server to scan to folders? for example "Scanrouter V2"? -you can check on your server in "start" , "programs", you will see it there if it's installed.
If so do this:
open "Scanrouter V2 admin utility"(you should just have to click 'OK' when asked for password -it's usually not set) then and under the "server" button select "set I/O device", then select "remove". If you are asked to "retain settings" select "no". Then add it again> click "add", then "Browse", it should find the machine (either host name or IP address), select "ok" then name it whatever you want - it's for identification only. Destinations should re-appear if you Update.
If you scan via SMB, Email or otherwise, you'll have to get your IT dept, or whoever configured in the firstplace to figure it out.
*please rate response :)
Posted on Mar 24, 2009
SOURCE: need to remove finisher
The SP mode is 6-101. Set to "0" (no sorter), and press "#" to save setting.
please rate solution :)
Posted on Apr 23, 2009
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Error code sc396
Drum motor bind. mechanical bind or defective motor. Hard to tell without a model #
Mar 05, 2012 | Savin Office Equipment & Supplies
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Error code E-4
You only have part of the error code. You need to hold down the "." key in order to get the rest of the code. Since there is only 3 error codes that begin with 4, I'll post them here so when you find out what the problem is, you can attempt to solve it.
E405 - Transfer belt/drum charge roller position abnormal
E440 - Main motor lock
E442 - Drum charge thermistor abnormal
It's most likely not the third, as this one doesn't normally cause the machine to stop operating. The first two can be reset by turning off the main power switch for a few seconds, then turning it back on. This will clear the error, provided it's not a hard error (one that reoccurs during the machines warm-up cycle).
Just so you know, due to the age, parts for this machine are getting hard to get...
Dec 16, 2009 | Savin Office Equipment & Supplies
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Need to remove finisher
Apr 22, 2009 | Office Equipment & Supplies
Copier error code
Mar 15, 2009 | Office Equipment & Supplies
52 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
