Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Beeps I get three long beeps when booting up my Gateway Performance 1600. What is that telling me?
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Can you tell me the model# of your pc? Gateway Performance 1600 sounds like a memory upgeade. Do you know your BIOS manufacturer? Different manufacturers use different beep codes to mean different things. The BIOS manufacturer may show up quickl on the cgreen when you try to boot. Probably the best way is just tell me the model # of your machine and if you haven't changed anything I can just look up the specks, check what BIOS you have and then tell you what the beeps mean and what do about it. Thanks.
    Jeff
    Master:
  • 441 Answers
3 beeps - Base 64 K memory failure
  • Reseat the memory.
  • Make sure that the contacts on the memory and the socket are clean.
  • Try removing one bank of memory modules at a time. Note: Some systems might need to have a memory module in Bank 0.
  • Try using RAM chips from the same manufacturer with the same part number and speed.
  • Check for a faulty memory module by trying the memory in a known good system.
  • Trying known good memory in the system.
  • Check the power supply and check for power fluctuations.
  • Swap the motherboard.
This does not apply to all mobo's. can you tell me the brand and model of your mobo (motherboard)
Posted on May 07, 2008
  • Serwen Bagadiong
    Serwen Bagadiong May 07, 2008
    It can also be a problem with your video card.
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
All i get is a beeping My gt5220 will not boot...help
Does there seem to be a pattern to the beeps? (long beep, pause, long beep or 3 beeps and a pause) The codes will depend on the motherboard and BIOS manufacturer. One of the Gateway code lists: http://support.gateway.com/s/MOTHERBD/Intel2/WMEBLKD925XBCLK/WMEBLKD925XBCLKfaq17.shtml .
One beep is a CPU error. Three beeps is a memory error - you can remove and reseat the memory one stick at a time to find a bad stick causing them all to fail. Eight beeps is a video error.
I hope this helps.
Aug 29, 2010 | Gateway GT5220 PC Desktop
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Problem booting
Any beep code from pheonix starting with two beeps relates to ram issues. If you have treid swapping the ram and it only gives the first 2 beeps then most likely the RAM controller on the north bridge or the data channels themselves are damaged on the motherboard.
You can try running a single chip of ram in each slot at seperate attempts. If it is a data channel damaged this will bypass the problem although it will cripple the laptops performance. Either way, the only permanent and proper fix would be to replace the oBo which I doubt would be cost effective on this unit.
Chris
Jun 02, 2009 | Gateway Solo 9500 Notebook
Gateway c140 beeps
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Mar 21, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
