Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Flashing LF - Whirlpool Cabrio WTW6600SBT Top Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 23, 2010
1982 chevrolet S10 Only headlights come one with
Voltage for the tail lamps shows to be a brown wire. Use a test light, check that wire for voltage, headlamp switch on. If voltage then check black ground wire.
A problem with grounds will cause some weird things to happen. Ground wires are black. You can use a test light to check ground, one end of testlight comes from battery voltage, the other end you touch ground, black wire, you have to penetrate the insulation. If the lite comes on, at least the ground is good enough for the test light.
At the moment, I don't care about the maker lamps. I do care about tail--stop--turn--tag lamp. In the past, I have been stopped because of no tag light.
Just my opinion.https://s9.postimg.org/af5e5kqtb/tail_lamps.jpg
Click on the link, hope you can read it.
May 30, 2017 | Chevrolet S 10 Cars & Trucks
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
What does the code LF stand for? It keeps stopping half way through the wash cycle and flashes this code.
LF is for long fill.
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Check the following:
? Is water supply connected and turned on?
? Are hose screens plugged?
? Is water entering the tub?
If all these are good and water is going in fast (both hot and cold) you may need a service company to come out and take a look
Apr 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Keep getting an LF error
Hi There
I have found something for to read and this should help you. Try this and let me know how it goes.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya. Merry X-Mass and a Happy New Year.
Best Regards Richard
Dec 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
80 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
