Question about HP Pavilion zd8000 Notebook
My screen on my hp pavilion zd8000 is cracked and now the screen is completly unreadable when i plug an external monitor in it does not reconize it any reason why?
    Sergeant:
  • 235 Answers
There is key combination like fn + 2 or something like that so that the video signal is sent out the external port. Try it!
Posted on Aug 23, 2010
Using notebook display and external monitor: HP Pavilion zd8205us primary display is garbled, secondary display is clear and good, It doesn't matter which display device you set as primary or secondary
try to switch the blue VGA cable that is connected from the laptop to the external monitor. You may also restart your laptop and set aside the external monitor to check if the laptop is still experiencing garbled display... If it still is, then it is a monitor issue and need to address to HP personnel by calling HP hotline. Otherwise your issue will be resolved by simply doing that..
Nov 14, 2010 | HP Pavilion zd8000 Notebook
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
Vertical lines have appeared on my hp pavilion zd8000 can u tell me how to fix it please?
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mptherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Oct 08, 2009 | HP Pavilion zd8000 Notebook
Hp pavillion zd8000 monitor has 37 vertical lines
Interesting that you counted them!
If you haven't tried to reinstall the video drivers, do that.
If that doesn't work, hook up an external monitor to see if the display is OK on that.
If it is, then your LCD screen has a problem and will need to be replaced.
Jun 29, 2009 | HP Pavilion zd8000 Notebook
Dark unreadable screen
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | HP Pavilion dv6000z Notebook
Screen is dark
DID YOU TRY EXTERNAL MONITOR TO SEE IF IT IS A SCREEN ISSUE
ROD
Feb 09, 2009 | HP Pavilion zd8000 Notebook
How do you turn on the dual monitor function HP Pavilion zd8000
Please check the Main monitor settings in Desktop - display settings. Also you can extend your desktop to the new screen.
Hope this change fixes your problem
Feb 07, 2009 | HP Pavilion zd8000 Notebook
Hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Nov 17, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 Manuals
Hi, the manual is available in FixYa itself.
The link is http://www.fixya.com/support/p381158-hp_pavilion_zd8000_pf456av_pc_notebook/manual-3309
One external link is
http://www.onlinefreeebooks.net/?s=Maintenance+and+Service+Guide+HP+Pavilion+zd8000+Notebook+PC.pdf+
May 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
