Question about Ricoh Aficio 450 Copier
I bought a ricoh 450 at an auction and i need to find out how to reset user code
  • Steve Helmstadter Aug 24, 2010
    of course that did not work,is there a way to
    do some sort of master reset?
    Top Expert:
  • Ricoh Master
  • 76,649 Answers
The Key Operator code allows access to the configuration of the machine and is
equivalent to the console root password of a server. Users can be tracked and their
access limited by assigning user codes with ID information. The assigning of user codes
is performed via the Key Operator code. The default Key Operator code is “0000” and
distinct User codes are not by default enabled. However, even if the Key Operator code
is set to a non default this can be overridden as detailed in the service manual by
entering service program mode, pressing the interrupt key then 107 on the keypad and
finally, holding down the <c> key for 3 seconds (Ricoh 1,pp.4-5). No authentication is
required. Once in this mode, all system parameters including the Key Operator code
can be reset to factory defaults. This not only allows the machine to be made inoperable
but also allows data to be archived to the hard disk or memory, allowing data retrieval at
a later date. An alternative way to achieve the same result would be to open the
machine, reset the systems NVRAM, automatically resetting the machine to factory
defaults.
Posted on Aug 24, 2010
    Brigadier General:
  • 3,513 Answers
Hi
This code can be reset by turning the machine off at the red power switch located on the left side of the machine. If this does not fix you problem, then the machine may need to be serviced.
Let us know if you have somethin more to ask else accept the suggestion.
Thank You for contacting Fixya
Asking input user code
Copier has been setup to use code. Will need to turn feature off if you don't want to it. Look in your manual or go to ricoh-usa.com/download enter model in search box click on manual
Jan 23, 2014 | Ricoh Aficio 450 Copier
What is error code SC326-00 on a Ricoh Aficio 450 copier?
326 error in laser unit . check ld conection and reset yourmachin
Jul 05, 2012 | Ricoh Aficio 450 Copier
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
I bought this gestetner 3227 copier at a auction but it has user codes on it and I don't know how to get past them to use my copier, can you help?
Yes, you can delete the User codes.
But first see if you also have administrator code. You have to know that first and then you have clearance to change the User codes.
All these instructions are in the user manual. You can download for free on the website of RICOH. The equivalent of your machine is AFICIO 220.
Jan 28, 2011 | Gestetner Office Equipment & Supplies
I need to reset the terminal name and number on the fax portion of the Ricoh Aficio 450 copier. Can anyone assist what that?
The fax user manual for the 450 is no longer available from Ricoh, so I can't check for sure, but the basic procedure is to press the User Tools button, go into Fax Features, and under one of the tabs will be a box where you can change the fax header information.
Hope that helps!
May 25, 2010 | Ricoh Aficio 450 Copier
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
Oct 15, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 1045 User Key
Someone locked the machine out. You can a hold of who your purchased it from to see if they can give you the key operator code to unlock it.
I can give you the service code to restore it but there are several steps involved in doing that.
If the first option doesn't work, let me know and I'll look up the service program to disable the key codes.
Sep 01, 2008 | Ricoh Aficio 1035 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh copier
Must have unplugged the thermister on the coupling connection bank. Reset fuser: Clear modes/ 107/ press and hold clear/stop. Pick copy sp. select mode. exit out of all screens and cycle power.
Feb 21, 2008 | Ricoh Aficio 450 Copier
User Manual
You can go onto RICOH>COM ,then go to manuals, then to users manual,and down load.Most all user manuals are free.
Oct 17, 2007 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
188 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
